Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Cellpro 4s Balancing Charger
Old 03-04-2007, 10:22 AM
  #176
N3CLI
Default RE: Cellpro 4s Balancing Charger
Greg
Wanted to know when your new Cellpro lipo line of cells will be in?
Will Fred have adapters for the Cellpro 4s charger for them to purchase ?
Thanks Fred Copeland
AMA 68196
Old 03-08-2007, 06:51 PM
  #177
WesInGolden
Anyone using the 1.4C charge rate on Thunder Power Extreme batteries, specifically the 2070?
Old 03-08-2007, 11:26 PM
  #178
connolly
so would i need an adapter to charge this battery? [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNYJ1&P=0]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNYJ1&P=0[/link] . i just got it over the internet and am trying to find a charger that will charge it with the balancing plug.
Old 03-15-2007, 03:21 PM
  #179
WesInGolden
Well I am NOW charging my TP 2070 at 1.4C! This charger ROCKS as the 1.4C charge rate saves me 10-15 minutes per battery. Interesting thing to watch is the actual charge rate on the cellpro; it ramps up and down to find the max charge rate. All 1.4C changes is the possibility that you can charge faster, it doesn't force the charge rate to 1.4C.
Old 03-16-2007, 05:52 PM
  #180
stashu
Mine smoked
Just received my CellPro 4s yesterday, had it 2 hours, plugged it in and poof!!, a small puff of smoke and that awful smell of electrical burnt components. I already sent it in for replacement. Called FMA asked about the refund of 7.00 to ship it to them, no deal, stuck with paying 7.00. So far 65.00 for charger, 8.00 shipping 1st time, and another 7.00 shipping--not fair.
Should of gave me a credit or something----anybody have any pull with FMA?
stashu
Additional: Would of liked free return shipping during the first 30 days, after that would pay return shipping.
Old 04-11-2007, 06:51 AM
  #181
marchambault
ORIGINAL: connolly
Yes ... you will need the "Cellpro-to-Great Planes ElectriFly "Power Series" " adapter, found here: http://www.fmadirect.com/Detail.htm?...196&section=45 ... the same adapter also works with LiPower Lites, EFlite, ParkZone, DualSky, Align and probably other manufacturers.
Old 04-13-2007, 11:11 PM
  #182
lunar_special
Can anyone tell me if I could use the FMA cellpro just hooked up to my car battery as a DC source. Is buying a dedicated power source really necessary?
If I must get a power supply, would this work:
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
Old 04-13-2007, 11:34 PM
  #183
MrMulligan
My Feedback: (314)
I use my Cellpro with a "start" pack. You know, the pack sold as an emergency starter for your car. I charge outside and this allows me to do it without running extension cords as I also have a dedicated power supply. Just be sure it's fully charged before using it. A car battery would be fine. Stay with it during the charge.
Old 04-14-2007, 08:47 AM
  #184
marchambault
Yes, the link to tower hobbies does show a suitable power supply. You may want to put connectors on the end of the power supply leads and charger leads. I used Anderson Powerpoles for this.
Although a car battery would work fine with the CellPro, it is probably not the most practical power source. A car battery is designed to deliver high current over short period of times, not low current over a long period of time. Using it all day long to charge your LIPOs could prove to be destructive over the course of the summer.
At home, I use a regulated variable output power supply for all my 12V DC: Alinco DM 330MV needs http://www.alinco.com/Products/DM330MVE I have also seen modified computer power supplies with banana plug terminals. http://www.wikihow.com/Convert-a-Com...b-Power-Supply
In the field I use a 80Ah deep cycle battery, which I charge about once every 3 weeks using an 10 Ah automotive charger.
Marc
ID:	663878   Click image for larger version
Old 04-14-2007, 08:58 AM
  #185
Flypaper 2
I use an automotive jumpstarter with a 20 AH batt. out at the field too. it also has a built in inverter that I use for a hot glue gun. It will charge steady all day but the biggest batt. I charge is 1800 MAH, most are 1320. It has two lighter outlets to run two chargers, the cellpro and a Triton. When I get home I charge the jumpstarter with the Triton.
Old 04-21-2007, 01:49 AM
  #186
jrob00
Thanks to some inspiration on another forum I hacked together a quick 'terminal box' which powers from a toshiba laptop ac/dc brick. The power supply says it puts out 15v at 2.7amps which is lower amps than I would prefer but it gets the job done thus far.
See the pics here: [link=http://i.ndustrio.us/2007/04/20/an-indoor-ac-solution-for-a-12-volt-lipo-charger/]http://i.ndustrio.us/2007/04/20/an-indoor-ac-solution-for-a-12-volt-lipo-charger/[/link]
Jason
Old 06-24-2007, 01:43 PM
  #187
trireme
I use a 35AH Lead acid, no problem. It will charge the battery several times without effecting the output voltage. High crank amp batteries do work fine for slow drain, they run the glove box light, and your car radio fine.... not sure why someone would be concerned about that. Actually typically a DC battery source, is more stable then a cheap AC to DC converter. The more stable the power, the more stable the charger will run... An AC/DC converter with enough amps will set you back a bit.
I cut the alligator clips right off, and soldered on a male 4-pin nuetrik XLR connecter, and then made a few different connectors, Alligators to four pin, AC/DC to four pin. I even got a motor cycle 18AH battery, and soldered a 4pin directly to that, I can easy carry that to the field. Charger works fine with all of them.
Old 06-24-2007, 02:18 PM
  #188
Red Scholefield
Banned
My Feedback: (9)
ORIGINAL: lunar_special
You can do a lot better than Tower for good power supplies. Here are three on line sources at good prices.
http://www.efunctional.com/new-pyram...-supplies.html
http://www.millionbuy.com/caudio-kit-sup.html
http://www.buyreliant.com/psupplies/...r_supplies.htm
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
