Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
Reload this Page >
Lipo % remaining capacity vs resting voltage
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 02-17-2006, 06:44 PM
guver
My Feedback: (325)
Default Lipo % remaining capacity vs resting voltage
Is there a accurate chart for lithium polymer for resting voltage vs. remaining capacity? Thanks, I'm new.
Here's all I have seen posted so far and wanted to update and check the accuracy and the bottom numbers as well as interpolate.
4.20 v = 100%
4.03 v = 76%
3.86 v = 52%
3.83 v = 42%
3.79 v = 30%
3.70 v = 11%
3.6? v = 0%
Old 02-17-2006, 07:53 PM
Hugeone
Default RE: Lipo % remaining capacity vs resting voltage
Well look pretty accurate, but it may be different form a brand to another...
Old 02-17-2006, 08:27 PM
guver
My Feedback: (325)
I would think that all li-po would be the same, I am looking for a chart that may show a (linear) graph with 10% increments,,,
Old 02-17-2006, 08:29 PM
guver
My Feedback: (325)
Here's another thought,,,,I will test a cell and see, but how about a procedure for testing?
first thought is to discharge at a very very slow rate taking hours to discharge and hopefully it will be very close to a "resting voltage" "?: just a thought,,, any other ideas? or existing charts?
Old 02-18-2006, 10:07 AM
JNorton
JNorton's Avatar
U-dUd
Look at the battery Vault.
http://www.rcgroups.com/forums/showthread.php?t=342568
John
Old 02-19-2006, 01:40 PM
guver
My Feedback: (325)
Thanks still researching, the place I got mine from is stating a minimum of 3 volts for a no-load voltage and others are using a 3.7.
I used 3.5 to keep it simple but wonder if I am even going too low.
Old 02-19-2006, 02:11 PM
JNorton
JNorton's Avatar
U-dUd,
What I've read it is 3 volts loaded. Great graphs aren't they.
John
Old 02-19-2006, 02:27 PM
guver
My Feedback: (325)
Yep, it seems that 3 volts loaeded is agreed (the load is not agreed however) but the resting voltage seems to be in great disagreement.
I am all "graphed out" I find it hard even to keep mine all organised so I can understand them, what a mess,,,
