1800 mH Tx Battery Pack
If your going to fast charge the pack you'll have to take it out of the transmitter! In the transmitter you normally have a 800 mAh pack, which is charged at C/10 or 50 to 80 mA. Trying to put 1.8 amps if it is NiMh pack or 3.6 amps if it NiCd thru it will blow the fuse if it has one or perhaps the circuit board traces if it doesn't. I don't see the sense in doing this but it is your transmitter.
John
John
