Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
testing amp draw
Old 05-26-2006 | 01:02 PM
Gringo Flyer's Avatar
My Feedback: (18)
Default testing amp draw
I am new to the electric side of RC and am interested in testing the amp draw of a motor and seeing if it runs in the range the manufacturer says that it does. I have a Sperry digital multimeter that I use to check some of my batteries with and I assume I can use to check amp draw. I am in now way an electrician so how would I do this?
Old 05-26-2006 | 01:54 PM
Default RE: testing amp draw
What model do you have? looks like most of Sperry models only handle up to 10 Amps. Anyway in the case you want to test I would recommend you take the manufacturer's word for it. An inexperienced user could really mess up there motor trying to do so. In fact you need a similar test environment to perform manufacture type measurements accurately. The last thing you want to do is hold you motor at stall unnecessarily just to get that max current measurement because you can easily burn it up.
Old 05-26-2006 | 01:56 PM
Banned
My Feedback: (9)
Your Sperry meter may not have a high enough range current capacity to check your motor current directly. You would need a shunt. FMA Direct has such a device or you could simply get a Wattmeter that gives you current, voltage, amp hours, and watts all on the same screen. Hook it between your battery and ESC.
Old 05-26-2006 | 02:11 PM
My Feedback: (18)
ok, I guess its a little more complex than I thought I checked out the Watt's Up Meter and I guess that is something I will eventually need to invest in.
Old 05-26-2006 | 02:14 PM
My Feedback: (18)
ORIGINAL: digregoriod
It is a himax motor rated at 4-11 continuos with 14 amp burst. So would you say that the manufacturers are generally on target with their numbers?
I know that manufacturers always try to streeeeetch their numbers to make things look better so I was a little worried that if they say the motor needs 4-11 with 14 amp burst that it is more like 6-14 with 18 amp burst or something similar.
Old 05-26-2006 | 03:38 PM
hands without shadows's Avatar
Max Amp draw is at a stall, cant u just hook up an ampmeter between the motor and a motor lead?
