Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
Reload this Page >
Accucycle Elite and Input Volt Calibration Message
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 07-10-2008, 07:40 PM
jzinckgra
jzinckgra's Avatar
Default Accucycle Elite and Input Volt Calibration Message
I have the above charger and every time I turn it now, I get the message "Input volt calibration" with some numbers. If you try and push any buttons, nothing happens. I turn it off and on and it still comes up. I've had this charger about 3 years. Anyone know what the deal is with this? There is nothing mentioned in the manual.
Old 07-11-2008, 05:48 AM
Hibrass
Hibrass's Avatar
Default RE: Accucycle Elite and Input Volt Calibration Message
jz,
Is it hooked to the AC/DC power supply? If so that power converter maybe failing. Try hooking it directly to a fresh 12volt car battery and see how it behaves...
If all of the above fail, send it back, Hobbico does a fine job at there repair site even for out of warrenty items..
Good Luck,
Old 07-11-2008, 08:00 AM
jzinckgra
jzinckgra's Avatar
Yes, it is hooked to the AC/DC PS and in additon to the calibration message, it shows the voltage as being 17.XXX, whereby it fluctuates. I did plug the charger into my 12V field batt power panel and that did get the charger working again, but only that one time. If I try the 12V now, it shows the same message with a volt readout of 12.XXX.
Old 07-12-2008, 03:19 PM
Hibrass
Hibrass's Avatar
jz,
Sounds like it time to send it back...
Good Luck,
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
