Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Triton and 9V
Old 06-18-2003, 12:19 PM
elevator_up
Default Triton and 9V
Anyone know the best technque to charge a 9V nicd or nimh with the triton ?
Old 06-18-2003, 12:24 PM
Doc11
My Feedback: (59)
Default triton
Use auto mode. Doc
Old 06-21-2003, 09:54 AM
bob_nj
My Feedback: (62)
I'm having a senior moment Doc. Tell me again how to set up for "auto" mode? The manual says it goes there if you don't set any parameters which I don't understand
Thanks_bob
Old 06-21-2003, 10:16 AM
Doc11
My Feedback: (59)
Default Auto
Press mode until you get the type of battery NI,CAD od? then turn wheel until auto is displayed then PRESS AND HOLD WHEEL DOWN FOR # SECONDS the charger will start. I am doing this from memory the charger is in my garage and I only have it for a week. If that does not work let me know. Doc
Old 06-21-2003, 10:40 AM
bob_nj
My Feedback: (62)
I'll give it a try. Thanks_bob
Old 06-21-2003, 11:37 AM
bob_nj
My Feedback: (62)
I still can't come up with it? I found it about a month ago, but I've slept since then
Old 06-21-2003, 11:52 AM
Doc11
My Feedback: (59)
Default Charger
Go to the manual, pages 7-8-9 and read over several times. Then hook up to 12v and put battery on to be charged. Play with the buttons and you will get it. Doc
Old 06-23-2003, 11:49 PM
RCBOZO
Hey bob_nj :
Select the type of battery that you are charging and the select the type of charge or discharge that you want to try. Once you have figured out what you want to do then PRESS the dial down for just a second this will make the amperage blink then rotate the dial for whatever amp. you desire. If you only want AUTO amp. just rotate the dial counter clockwise till it shows you AUTO then PRESS the dial again for about two seconds this time that will " SAVE " the AMP. and start the cycle.
Good luck!
I usually just charge my 9V Transmitter battery at 1 amp. The AUTO Charge takes TOO Long. But thats my opinion.
Old 06-24-2003, 06:55 AM
bob_nj
My Feedback: (62)
Thanks again_bob
