battery charge time ?
im new to the rc world. just purchased a traxxas stampede. i went ahead and bought a venom 5000 7 cell 8.4 how long does it take to charge? its been about ten hrs and the light on the charger still red. do i need something better than the stock charger that came with it or is this charger good enough?
Thanks for the help
Thanks for the help
My Feedback: (325)
RE: battery charge time ?
Hi, and welcome to RCU. It will depend on the charger's rate (current or amps)
If the charger is 500 ma then that delivers 500 mah (per hr)
If it happens to be 5 amps then that is 5000 mah (per hr)
Banned
Location: hervey bayaustralian best town ppfftt, AUSTRALIA
1 Post
Off memory l think that charger is around 300Mah, it will probably mistake the peak charge level as well and sometimes not charge the batteries at all.
Consider a new charger, one that can charge at 5 AMPS will charge that battery in about 40 minutes.
Get one with an adjustable voltage via a digital screen, then set it to 3.5 AMPS and that battery will last alot longer.
Charge it at 1 AMP for a slow cool charge .
At 5 AMPS charge the battery will get pretty hot. Not recommended for ni cad or Nm batteries 5 AMPS.
At 3.5 AMPS the battery will get nice and warm.
At 2 AMPS it will get luke warm.
At 1 AMP it stays cool.
Next time you buy a battery consider LIPO as a replacement.
30 bucks gets you a 7.4v ,5000mah and it will smash the 8.4 one you have !
Banned
Always trickle/slow charge a new battery overnigt to get the best preformance of a new battery. Never fast charge. it's ok to Quick charge for 1 hr after you trickle/slow charge.
TX
ORIGINAL: mrboombastik
Thanks for the help
Thanks for the help
Wall charges just have indicators in red, meaning they are connected and working. So it will not go on or off, it will stay on as long as you have it connected.
Hope that helps you.
Chip
