Lipo died? Help?!
UT
Lipo died? Help?!
Hey everyone, I have 2 lipos I use for my 450 size heli, there 11.1 v, 1500mah, 25c.. Yes that is a little small for a 450, but it works for me. So I just moved from Texas to Nevada, when I was in Texas they worked fine.. I made a pit stop in Utah, they worked fine there.. I actually went to Idaho then back down to Nevada.. When I got here one of them had ballooned out for some reason unfortnatly, the other one I put on the charger before I used it, but something weird happened, it almost immediatly went into drip charging.. I plugged it in anyways, but nothing happened.. I don't have a volt meter to check them, so I connected the positive to the negative, no spark or anything, on either one, I even touched theirs tips while it was on the charger, still nothing.. Does anyone know why or how there's doing this? Why would one lipo blow while it was just sitting iN my suit case, I've blown a lipo before, but from missising it(it was my first on >_
My Feedback: (110)
PA
RE: Lipo died? Help?!
li-po's are known for that. unless you discharged it to far. thats 3.2 volts per cell minumin. you can buy reasonable lipo's from[ value hobby .com ] and they don't rip you off for shipping.......check then out on the web.............RON
