Please help identify this balance connector
I am attempting to convert this battery over to charge on my Hyperion EOS6060i and need to identify the balance plug used on this pack so I can get an adapter (to either Hyperion or JST) or find the balancer plate to use with the charger. (The balance is the white plug, of course).
Thanks in advance. http://i.imgur.com/6p9AX.jpg |
RE: Please help identify this balance connector
picture???
sry didnt see pic first time
it looks like a standard 3 pin type balance plug im assuming it doesnt fit the balance board you have?
ORIGINAL: doug702 it looks like a standard 3 pin type balance plug im assuming it doesnt fit the balance board you have? |
Pretty sure that Losi batts come with a xh balance connector. It should fit the board closest to the battery. Try orienting the connector 180 degrees in both directions...it should fit. Also make sure you are putting it into the 2 cell slot.
KMac |
ORIGINAL: GR7Racer Pretty sure that Losi batts come with a xh balance connector. It should fit the board closest to the battery. Try orienting the connector 180 degrees in both directions...it should fit. Also make sure you are putting it into the 2 cell slot. KMac EDIT: Nevermind on the FMA, even the 2s taps are 5-pin. |
Here is a closer picture comparing the plug to the XH board 2 cell slot.
http://i.imgur.com/wsZ8m.jpg |
Is FMA the only one with 1mm pin spacing? TP is 2.0 and all others are 2.5 mm. Losi (according to my list) is XH , but your losi pack doesn't look familiar.
ORIGINAL: guver Is FMA the only one with 1mm pin spacing? TP is 2.0 and all others are 2.5 mm. Losi (according to my list) is XH , but your losi pack doesn't look familiar. |
