run time?
Higuys how do you make nimh batteries have a longer run time? thanks</p> |
RE: run time?
hi guys
How do you get a longer run time for a nimh batteries in an rc car? Thanks |
RE: run time?
Same as any battery, can larger capacity (mah).
RE: run time?
Or drive slower and stop at the lights!<div>
</div> |
RE: run time?
slow charge rate will give it better runtime.
what Mah battery ya got ? |
RE: run time?
Use them at a slower rate. ;)
RE: run time?
Mah is like gas, more mah = more distance. More weight, tho. [:o]
RE: run time?
Youll add weight if you go up from a 6-cell to a 7-cell battery.
