A123 battery
New to the A123 Battery. I have 2- 2cell A123 batteries in this edge 540 i bought i was wondering how to charge them i have a Titan B6 digital charger. What setting do I set it at ?
RE: A123 battery
what capacity are the combined cells? You can charge lipos at around 1c, A123 a bit quicker. A safe level would be if its a 4000mah pack I would charge at 4amps (that is 1c)- but you could probably charge at 20amps (5C).
I trust your charger has an A123 setting? |
RE: A123 battery
If it doesn't have a LiFe or A123 setting, then simple, don't charge them with it.
RE: A123 battery
Yes, but if does have a life or lipo setting the ampage will also have to be set?............
RE: A123 battery
If they are true A123 batteries then they can safely be charged up to 9.2 amps. (4C or 4X2300=9.2 amps)
RE: A123 battery
ya i found the life setting on my charger. :) Now i should be able to get them charged . The setting i can charge at is .1amp. Can i set it up higher?
RE: A123 battery
Erm read what Jezmo said just before you asked the question........
