Thunder 1220 charger problem
Hello,
When I hook my Thunder 1220 charger up to my 500w power supply it runs through the normal setup which shows its connected to the 500w power supply, but then I get an ERROR car batt. empty message. Whats up with it? Thanks |
RE: Thunder 1220 charger problem
Have you used the 500w supply before? If not does it have a setting for output voltage, it might be set too low.<div>
</div><div> </div> |
Turned out to be the power supply. Adjusted the output & still didn't work. Plugged into my 350w power supply & worked fine. It was new out of the box. Sending it back for replacement. Thanks for responding!
