RCU Forums
-   Batteries & Chargers (https://www.rcuniverse.com/forum/batteries-chargers-84/)
-   -   Is the so-called "smart battery" really safe enough? (https://www.rcuniverse.com/forum/batteries-chargers-84/11668599-so-called-smart-battery-really-safe-enough.html)
Chamberlainr 08-21-2019 01:40 AM
We have read many news about fire caused by drone battery. Some of them are due to battery overcharing, when a LiPo battery is overcharged, the anode of the battery becomes plated with lithium metal and the cathode produces carbon dioxide. The pressure inside the battery rises as more gas is produced until the outer skin of the LiPo bursts and vents gas. LiPo venting is usually accompanied by flames which leads to the entire battery destroying itself. Overcharging can be prevented by charging LiPo batteries to a maximum of 4.2 volts per cell (or 4.35V for lithium high voltage packs) and charging at a safe current setting.
Some due to over discharging. When quickly discharged in situations such as a drone race, a LiPo battery will heat up. If excess current is drawn from the battery causing it to overheat, gasses will form inside the battery. Like overcharging, if enough gas forms and the LiPo bursts, it will commonly vent with flames. If a LiPo is discharged below its stated C-rating, there should not usually be a safety issue (unless, as happens occasionally, LiPo manufacturers lie about the C-rating of their batteries).
I found some smart battery claiming it can prevent over-charging and over-discharging automatically, so does this mean it is really safe enough that we don't have to take precautions?
init4fun 08-21-2019 03:22 PM
Originally Posted by Chamberlainr (Post 12545064)
..I found some smart battery claiming it can prevent over-charging and over-discharging automatically, so does this mean it is really safe enough that we don't have to take precautions?
Can you show me some links of where you found the "smart battery" LIPO of which you speak ?
BobbyraMarquezr 08-21-2019 06:04 PM
It is called MMC TI22000 smart battery and I browsed it around on other forums. I will PM you the link.
Bruces 09-23-2019 10:58 PM
I don't think there is an absolutely safe battery, but at least it is safer than other batteries
ticedoff8 09-27-2019 05:11 PM
The MMC TI22000 is a commercial drone battery and not a hobby battery. It requires as specific charger that matches the battery.
AllModesR/C 10-04-2019 02:34 PM
Never mind, it just needed to rest for a while.
