Charging 1S 70 80 mAh LiPos
Hello,
Im just starting out with the hobby and the model I got had 70 mAh Lipos recommended for lighter flight, so i got one to try, but i think the stock charger is too strong to charge such small battery (Eflite 1S usb LiPo charger, 300 mA). After learning about Lipo i noticed that that charger should be to strong for charging it safely and withouth damaging the battery. So im scrolling around internet to see what chargers have a possibility of charging such small 1S batteries at 1C. I could find no infromation out there on what chargers are best or even able to charge it. Manifacturers dont recomend any for the batteries that size, and noone is writing on how to charge such battery safely. So please, could someone recoomend a buget beginner charger that would charge 70 mAh battery to help out a newbie? Thank you in advance |
Originally Posted by WildOtter
(Post 12752942)
Hello,
Im just starting out with the hobby and the model I got had 70 mAh Lipos recommended for lighter flight, so i got one to try, but i think the stock charger is too strong to charge such small battery (Eflite 1S usb LiPo charger, 300 mA). After learning about Lipo i noticed that that charger should be to strong for charging it safely and withouth damaging the battery. So im scrolling around internet to see what chargers have a possibility of charging such small 1S batteries at 1C. I could find no infromation out there on what chargers are best or even able to charge it. Manifacturers dont recomend any for the batteries that size, and noone is writing on how to charge such battery safely. So please, could someone recoomend a buget beginner charger that would charge 70 mAh battery to help out a newbie? Thank you in advance The reason is that when you charge in parallel, the sum of each pack's capacity determines the current needed to charge all of the packs in parallel at 1C. So, if you have 4 70mAh packs in parallel, they will need a 280mA charge rate to give each pack 1C. So, 300mA is about right. Parallel charging is safe and is common. You just need to create a 5 connector "hydra-cable" to connect 4 packs to 1 charger. |
Originally Posted by ticedoff8
(Post 12752997)
Your "best bet" may be to charge 4 1S 70mAh pack in parallel at the same time using the 300mA charger.
I charge my 150 ma 1s batteries with a 300 ma charger and they charge fine. I'd just try one and see how it responded. Not a whole lot of expense if it fries.
Originally Posted by Big Alice
(Post 12753625)
Charging a 70mAh pack at 300mA is 4C charge rate. There is no need to "try one and see". Even if you take the pack off the charger in 7 or 8 min, the batteries will definitely be fried in only 1 or 2 charge cycles because they are not designed for a fast-charge. |
I got a charger that can charge at 0.1 A so I planned to charge 70 mAh (1C for it would be 0.07A?) and charge it at 0.1 rate. That would make it just a bit over 1C if I calculated it correctly? Parralel also looks as an option, but I need to get more of same type batteries and needed cables and read up on it a bit more.
(Post 12753641)
Charging a 150mAh pack at 300mA is 2C charge rate - you can get away with that as long as you are careful and only charge for 20 min or so.
The charger I use for the 150 mah packs came with the model the batteries came with. Shuts off when the battery's full. So it's probably the right charger for the job. I don't care enough to argue about it so I'm going to leave you to your problem. Good luck.
