RCU Forums
-   Batteries & Chargers (https://www.rcuniverse.com/forum/batteries-chargers-84/)
-   -   Safe Minimum Flying Voltage (https://www.rcuniverse.com/forum/batteries-chargers-84/1750104-safe-minimum-flying-voltage.html)
splais 04-22-2004 10:17 PM
What is considered the safe minimum flying voltage for 4.8v and 6v batteries. I never let mine get low, but I've always wondered about the actual low safe voltage. thanks
Jim Schwagle 04-23-2004 08:42 AM
RE: Safe Minimum Flying Voltage
I believe if you get below 1.2V per cell, you're flying on borrowed time. I won't take off if a 4 cell pack is down to 4.9V and a 6 cell pack is down to 6.2. Actually, I tend to field charge them at 5.0V and 6.3V. I'm sure there's a lot of usable current left, but better safe than sorry.
Ross Kean 04-23-2004 09:21 AM
Jim
Do you mean 7.2 V for the 6 cell????
Ross
smokingcrater 04-23-2004 10:17 AM
think he meant 6v, 5 cell pack...
jalusa 04-23-2004 10:30 AM
I would like to hear other comments on this. Is this correct? The pack is rated at 4.8 volts, so at 4.9 it is still in an overcharge state...
I really have no idea, just want other opinions.
splais 04-23-2004 04:19 PM
Yes, I was referring to 4 cell and 5 cell packs.
sfaust 04-23-2004 05:27 PM
1 Attachment(s)
4.8v and 6.0v are conservative readings for a 4cell and 5 cell pack. At these readings, if taken with a good ESV meter with a 250ma load, there would be more than 50% of the capacity remaining in a normal pack under normal flying conditions.
I typically fly mine to 4.7v and 5.9v, which leaves about 3 flights in reserve. I arrived at 4.7v and 5.9v from bench testing and then field testing with constant monitoring to verify that I am actually leaving about 1/3rd of the rated capacity and a 3 flight reserve for safety. If you are not consistent enough to monitor your packs, or don't want to take the time to do capacity checking, just fly to 4.8V and 6.0V. This will put you at the start of the flat portion of the discharge curve, or leave you with about 50% remaining capacity. In essence, a very conservative and safe cut off voltage.
The attached chart shows the discharge curve for one of my 5cell packs. You can see that at 6.0v, you are only about 1/3rd of the way into the total capacity. Very conservative. At 5.9v, you would be about 2/3rds into the capacity, with about 1/3rd remaining capacity. Still more than enough of a safety buffer if you have verified your ESV meter with a capacity cycle to verify its reading properly and at 5.9v, you do indeed have 33% remaining capacity.
The pack below was a well used NiMh 2700mah pack taken from a 40% Giles 300. However, it is typical with any of the other packs I use, both 4 cell and 5 cell. The discharge curves are very similar.
ZM2000 04-26-2004 02:27 AM
I second SFAUST.
After extensive research and practice; I check with a loaded voltmeter and stop flying when 4.8 volt batteries are down to 4.7 and 6 volt batteries are down to 5.9 volt.
-ZM
rajul 04-26-2004 05:12 AM
Speaking of loaded voltmeters, when do you use 0.5A, 1.0A, and 1.5A with respect to the battery capacity ?
sfaust 04-26-2004 07:17 AM
I try to base the loaded ESV meter reading to minic the potential load on the battery from the airplane. Basically, I use 250ma for my smaller airplanes (typically 4 or 5 channels, under 80" wing span), and use 1amp for the larger airplanes (8-10 channels, 10-12 servos, etc), and .5amp for those inbetween. I stick with that loaded ESV value for all measurements, be it capacity testing, discharging, plotting the battery curve, and measurements at the field. Consistency is probably far more important that the actual loaded value used, as your readings will be more predictable with a consistent procedure. If in doubt what to use, error toward a higher reading, but no need to go overboard either.
