oop quick question
I have a powerflite redundant battery li-ion pack. I dripped a little ca on one of the wires on accident while working on my plane well when I was moving one of the wires the sheeting cracked in 3 spots Right next to each other where the ca dripped it does not look like the sheeting cracked all the way to the metal wire but close. I just wrapped it up good with electrical tape I tested and everything powers fine. I assume this will be ok since the wire itself never got severed but I want to be sure using the electrical tape is the right idea.
Thanks Rob |
RE: oop quick question
Electrical tape does a good job of hiding the problem but does a poor job of properly repairing exposed wires/damaged insulation. I would either replace the connecting wire or use some heat-shrink. I assume the battery covering was not damaged.
Ross |
| All times are GMT -8. The time now is 07:40 PM. |
