Initial charge settings
I just got an einstein and a new 1100 mah tx pack can i use the 120 mah setting for 16 hours for the initial charge without causing any damage, i realize this is a bit over the c/10 rate but is is closer than the next choice which is 80 mah.
Re: Initial charge settings
Originally posted by SuperStick I just got an einstein and a new 1100 mah tx pack can i use the 120 mah setting for 16 hours for the initial charge without causing any damage, i realize this is a bit over the c/10 rate but is is closer than the next choice which is 80 mah. |
thanks red and by the way i hear you just had a birthday. Happy Birthday
| All times are GMT -8. The time now is 11:57 PM. |
