RCU Forums
-   Batteries & Chargers (https://www.rcuniverse.com/forum/batteries-chargers-84/)
-   -   NiMh Problems (https://www.rcuniverse.com/forum/batteries-chargers-84/5541152-nimh-problems.html)
piercemartin 03-10-2007 05:19 PM
NiMh Problems
I have 4 8 cell 1400mah 9.6V battery packs. Some of these batteries seem very weak and will not even power my brushless motor for more than 10 seconds before slowing down. When charging some of them after a complete discharge it says it only reaches 100mah. One of the packs seem to work fine. Are the batteries just faulty or something?
KC36330 03-10-2007 07:22 PM
RE: NiMh Problems
have you 'form' charged them at all?
kc
piercemartin 03-10-2007 07:27 PM
RE: NiMh Problems
I do not know what that means so probably not.
KC36330 03-10-2007 07:32 PM
RE: NiMh Problems
NiMh batteries need to be Form Charged the first few times they are charged, this is accomplished by charging at C/10 for 16-24 hours or till the battery starts to get warm. if you do not form charge them they'll false peak when used with a peak detector and never achieve their designated capacity.
over time and many cycles they can be form charged to help bring them back up to par when they seam to just not put out what they once did, often it'll bring them back to full capacity and you can go back to quick charging/peak detecting.
kc
piercemartin 03-10-2007 08:02 PM
RE: NiMh Problems
ok thanks i did not do that so that is probably why. I will try to do that a few times.
KC36330 03-10-2007 08:03 PM
RE: NiMh Problems
that should defiantly help.
kc
