Testing voltage
How do I check the voltage on my 11.1V LiPo battery pack?
RE: Testing voltage
You can use a voltmeter.
To do a more accurate test you should do this with your cells under a load. How much of a load for this type of pack.... Perhaps someone will have some more info on this. Ryan |
RE: Testing voltage
if you just want to check the voltage just do the end that hooks up to whatever you are using it for. If you want to do it on the balance end then do this. Pretend the pins are numbered 1 2 3 4, measure pins 1 and 2, pins 2 and 3 and pins 3 and 4. All of them should be really close to each other for the pack to be in balance. Usually 0.02v or less. If they are more than 0.2v apart though then they are probably too out of balance to be using.
| All times are GMT -8. The time now is 01:45 AM. |
