Hobbico Multicharger and 6V packs
Can the Hobbico Multicharger charge a 6V battery pack? It doesn't have a voltage selection on the charger itself, but according to Tower, you can charge a 12V starter battery with it. So will it also charge a 6V pack?
Thanks |
RE: Hobbico Multicharger and 6V packs
It should do a 6 volt pack no problem. I'm haveing a hard time seeing the voltage range, but it does talk about 1-3 cells , rx packs and tx packs. I'd call it 1-10 cells without further research.
