Parkzone lip and ICE charger
Here is what I have:
Parkzone 3s 1800mah lipo (PKZ1030) that comes with the T-28 Trojan Eflite 2s 850mah lipo that comes with the Blade CX Both of the above have the same balance lead (JST/molex series 4 pin with 2.5mm pin spacing which I understand is an "align" style) I have a DTX ICE charger which I can connect to charge these, but it doesn't have a balancer. This is my question, please don't answer unless you can give specifics about balancer and adaptor brands (part numbers would be great) - I understand the principles for charging and balancing lipos, just can't seem to get straight answers on what specific items to plug it all together. I want to setup a balance charging system with these batteries and the ICE. What would be a balance charger and specific adaptor cables I need so the plugs are all compatible? (I already have the proper adaptor to go from the ICE Dean's plug to the discharge connectors on the batteries for straight charging without balancing.) Again, please, no generalities or suggestions on other batteries, etc. What cables and balancers would make this specific setup work to balance? Thanks! |
RE: Parkzone lip and ICE charger
the equinox will do what you are looking for (inline jst balancer for parkzone greatplanes esky eflite align ect ect ect) =) correct polarity, and correct balance tap (jst)
that should answer your q pretty specifically =) |
mrasmm
Thanks! |
you're welcome =)
I picked one up at my hobby store yesterday. Everything works very well. Out of the box it works with both my BCX and T-28 batteries. Owe you one buddy!
good deal =)
