RCU Forums
-   Batteries & Chargers (https://www.rcuniverse.com/forum/batteries-chargers-84/)
-   -   balancing adapter (https://www.rcuniverse.com/forum/batteries-chargers-84/6837012-balancing-adapter.html)
kenneth2 01-01-2008 02:38 PM
balancing adapter
1 Attachment(s)
oops did not porperly attach picture on last last post here it is.
I was wondering which connector I would need to balance common sense r/c 3 cell lithium packs to a sky holic charger. Even if I found out what type of connector is on the common sense batteries I can probably find the adapter. I have attached a picture if it helps. Thanks for any advice!
Tram 01-12-2008 12:47 PM
RE: balancing adapter
Our V2 line of 2S and 3S batteries is directly compatible with the stock E-Flite and Esky chargers. This applies ONLY to our V2 battery packs, which have a blue bar on the left side of the label. As the polarity is reversed for our older packs.
They are also compatible with "Align" balance connectors.
Jeff
www.CommonSenseRC.com
