Engine starter's battery
The battery that can be directly connected to a popular engine starter no longer charges. I can't even get it to discharge.
It is a sealed, lead acid battery. Is there any way to resurrect it? |
I have some batteries you would like....see ebay, below, or email me, These are great for our starters see this site/
(http://cgi.ebay.com/ws/eBayISAPI.dll...em=1775071288_ Copy and paste or click here !Text |
If it won't charge or discharge... its done. Try to find the proper recycling facility. (the local hospital can help you find where to send it... they go through a LOT of batteries. Occasionally, they'll take it for you.)
The lead and acid of these batteries should be kept out of landfills if possible. |
These batteries can fail very suddenly. Some of the imported batteries have a very small anode connection that just plain disolves long before the battery is done. The heavy current draw has a lot to do with the problem since internal heat accellerates the reaction. A bigger battery usually lasts longer because it's internals are heavier and not subject to the effects of heating to the same extent.
| All times are GMT -8. The time now is 01:09 AM. |
