I need help with GT A-6 Charger
Hi,
I need some help with the GT A-6 charger. I just bought it and I need to know if you can use the USB setting and the TEMP setting? I view the details through the USB but it shows no TEMP. I should be able to use both if it shows a VOLTAGE and TEMP setting through the USB...? Any help ASAP would be highly appreciated! Thanks! |
