New battery sugestion??
1 Attachment(s)
Hey, i want to buy a new battery, at the moment i only have a 7.2v 1800mah ni-cd which came with my truck. I want to buy around 3500mah ni-mh. The charger im using is just the charger i got with my truck, which charges 7.2v 1800mah ni-cd. If i bought 7.2v 3500mah ni-mh would i have to use a different charger or use the one i have now?
Where can i get the cheapest batteries which are around 3500mah? (preferably Australia) Is this venom battery a good battery to buy? |
RE: New battery sugestion??
All very interesting and basic questions however they are about Ni batteries and this is the A123 Racing (LiFePO4) battery support forum.
You would need a different charger. Nicds and NiMH require either different chargers or a chargerwhich can be set for different type batteries also a higher capacity battery would require a higher charge rate or much longer to charge. Charles |
HI, IS Ni-MH 4800mAh ok? Hope you good luck! More info ,contact me freely!
