RCU Forums
-   Batteries & Chargers (https://www.rcuniverse.com/forum/batteries-chargers-84/)
-   -   simultaneously charging multiple batteries (https://www.rcuniverse.com/forum/batteries-chargers-84/8178537-simultaneously-charging-multiple-batteries.html)
Busha 11-24-2008 01:02 PM
Hello All:
I use 3S 11.1V batteries with the same mAh and would like to charge at lease two of them simultaneously to cut down on the wait time for recharging at the flying field. Any suggestions on how to accomplish this? I currently charge one at a time using the Trinton Jr with plug in balancer.
Thanks all
Busha
guver 11-24-2008 01:31 PM
RE: simultaneously charging multiple batteries
They can be charged parrallel by hooking the + together and the - together. The charge rate can be doubled now.
The TrtionJr may be limited to 5 amps and 63 watts and depending upon what original rate youp've been using may not quite cut the time in half.
The balancer can be paralleled also or just used seperately on each pack even while chargeing.
