Which Battery and why
Can someone please explain the difference between these two batteries and why I should pay more for the one
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNHS4&P=0]Hobbico HydriMax 5C 6V 2000mAh NiMH AA Flat Receiver U [/link] or [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLX50&P=0]Hobbico HydriMax 5C 6V 2000mAh NiMH Flat 4/5A Rx U Pana[/link] Thanks in advance, Dan |
RE: Which Battery and why
ORIGINAL: secret_squirrel Can someone please explain the difference between these two batteries and why I should pay more for the one [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNHS4&P=0]Hobbico HydriMax 5C 6V 2000mAh NiMH AA Flat Receiver U [/link] or [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLX50&P=0]Hobbico HydriMax 5C 6V 2000mAh NiMH Flat 4/5A Rx U Pana[/link] Thanks in advance, Dan TIA again, Dan |
Before you invest in a new nimh pack, you should look at the 2300 mah A123 battery pack. Take a look at www.hangtimes.com to understand the A123. You won't regret it.
ORIGINAL: Capt Lou Before you invest in a new nimh pack, you should look at the 2300 mah A123 battery pack. Take a look at www.hangtimes.com to understand the A123. You won't regret it. Thanks though. Still curious on peoples thoughts. Dan |
Hopefully someone will answer the question though.... both 2000mah packs and one considerably more expensive than the other..... ?
Ernie |
Well I don't know a ton about these things, but:
The Panasonic cells are smaller and have the same capacity, thus they are more expensive. It is important to note that the 4/5A pack is NOT recommended for high discharge rates associated with digital servos - they will draw too much current and drop the voltage below a safe operating level. The Sanyo cell pack is larger but is also lighter. It is approved for high discharge rates as stated on the page. Lucky you, you need/want the less expensive AND LIGHTER pack;) |
ORIGINAL: gaRCfield Well I don't know a ton about these things, but: The Panasonic cells are smaller and have the same capacity, thus they are more expensive. It is important to note that the 4/5A pack is NOT recommended for high discharge rates associated with digital servos - they will draw too much current and drop the voltage below a safe operating level. The Sanyo cell pack is larger but is also lighter. It is approved for high discharge rates as stated on the page. Lucky you, you need/want the less expensive AND LIGHTER pack;) Thanks for confirming my thoughts. I purchased the Sanyo pack. Last question. Is there any difference between 4/5a packs and AA packs besides size/weight? TIA Dan |
Actually, the Panasonic is a 4/5A is a shorter fatter cell, the AA cell is longer and thinner.
Unless the small increase in weight and size is critical, for high current operations you are better of with NiCad rather than NiMh as they have a lower internal impedance and will give you twice the liftetime (number of charge/discharge cycles).
Save your money and make your own packs. I use DURACEL 2650 MAH from WALMART and the work just fine.;)
How are you going about soldering them together?
Thanks, Ernie |
Making your own battery pace is easy. Use a 100 wat soldering gun. scuff the ends of the cells, apply a little flux, then a small drop of solder. You can us Ks brass material for bars between the batteries.:D..
Ahhh the 100 W soldering does the job FAST so as not to overheat the battery internals I bet. Great idea. I once thought it might be a good idea to put a piece of flexible wire between the cells so you could cram them into the tight places like way back into the tail or something.
Ernie |
