Reload this Page >
F4U CORSAIR RC
F4U CORSAIR RC
Old 01-23-2011, 08:45 AM
mrcoolpop
Default F4U CORSAIR RC
I know there are a lot of good season pilots on RC that have a lot of experince. I am looking for some advice on what engine t0 put in my F4U CORSAIR RC for this flying season. I'm not sure whether a 2 stroke or 4 stroke would be good for this plane. Looking for advice....thanks
Old 01-23-2011, 08:54 AM
Gray Beard
My Feedback: (-1)
Default RE: F4U CORSAIR RC
You never mentioned what size of plane or engine?Type is a pilots choice, they both work very well. As a choice I always go four stroke but I have several on hand. I like four strokes better then two strokes but every once in a while I build a plane that a two stroke just works better. I also try to always use what I have in stock so I don't have to run out and buy a new engine, spending money without reason makes no sense to me. Do you have an engine on hand that would work or do you need to buy a new engine for this plane?
Old 01-23-2011, 10:58 AM
Stick 40
If cost is no problem, I would go with the four stroke every time with that plane. The sound is just worth it, but if money is a show stopper go for the 2 stroke!!!!
Like he said, size matters!
sticks
Old 01-23-2011, 01:08 PM
mrcoolpop
I want to build the 60 size airplane. I don"t have an engine yet so I need to purchase on. Money is no problem I just want to get the best that will go with it.
Old 01-23-2011, 02:34 PM
jeffie8696
jeffie8696's Avatar
Cant go wrong with an OS65AX and for a four stroke a Saito 72 would be my prefered engine.
Old 01-23-2011, 03:25 PM
delman
For a 60 size corsair, you would probably want to use a 91 four stroke to help with balancing and to swing a larger prop with the big round cowl.
Old 01-23-2011, 04:33 PM
thedeeman
If you can a 100 size 4 stroke (OS or Saito) has good power for a 60 size corsair. If your building a Corsair ARF like the Hangar 9 then even a 91 size 4 stroke will be good because they build pretty light. But if you are doing a kit built like the Top Flite, you'll probably need a 115 or 120 size 4 stroke as they build a little heavy. I have a hangar 9 and I've flown it with a Saito 100 and now have an OS 75AX (2 stroke) in it. I went with the OS75AX because I wanted a little more speed out of it.
Old 01-23-2011, 05:23 PM
Gray Beard
My Feedback: (-1)
ORIGINAL: delman
+1. I use the OS .91 four stroke in most of my 60 size planes. Lot of power without being too over powered. I do have the SK .91 two stroke in one 60 size plane and the YS 1.10 in another. The YS is what I would call over powered just a tad but it really gets with the program. Can't go wrong with the OS until it comes time to pay for it!!
Gene
Old 01-23-2011, 06:04 PM
mrcoolpop
Someone in my club gave me an old 4 stroke that hasn't ran in years. Some rust on it and looks like it need a good cleaning. I wish I could use it instead of buying one. What can I do to see if it works?
Old 01-24-2011, 12:21 AM
jeffie8696
jeffie8696's Avatar
If you could post a photo of the 4 stroke Icould give you a better idea of weither it can be saved.
what is the flying weight of the corsair?
Old 01-24-2011, 08:14 AM
mrcoolpop
Jeff,
I posted some pic of the engine on my profile pic page so you can see the engine. Let me know if it can be used....thanks for you help
Old 01-26-2011, 04:58 PM
sir_flies_alot
that's a two stroke OS.  Hard to tell what size, but what you are seeing isn't rust, it's castor build up.  Does it turn freely by hand?  Is it smooth?  IF the answers are yes, then tune it up and run it!
Old 01-26-2011, 05:16 PM
cfircav8r
cfircav8r's Avatar
RCV90-sp It fits in the cowl and swings a huge prop for a much more scale appearance.
Old 01-26-2011, 10:53 PM
ho2zoo
I have the Top Flite Corsair with an OS .91 2-stroke in it. I used a 2-stroke because it fits entirely inside the cowel. It's mounted on it's side (rather than inverted) to help it run better and to route the exhaust out the bottom with a pitts-style muffler.
Runs great and has plenty of power!
Old 01-27-2011, 09:49 AM
mrcoolpop
Ho2zoo, can you post a pic of your plane?
Old 01-27-2011, 10:44 PM
bigtim
My Feedback: (13)
were you going to build a Top Flight 60 Corsair or get a ARF
the Top Flight can be a hand full to build and fly and is a good match for a 91-120 4stroke, or even the new DLE 20 looks interesting for gasoline power.
a good ARF Corsair is the Hangar-9, there light weight 6-8lbs, and the H-9 planes fly really good, a 91 4stroke is a good match for the H-9 planes, I have a, P-40 warhawk, a P-51 Mustang, and the Corsair, there all fine planes there powered by OS91 4strokes
Old 01-28-2011, 12:50 AM
ho2zoo
Here's my Corsair...
Old 01-28-2011, 04:02 AM
CGRetired
CGRetired's Avatar
I LOVE Corsairs!!!
CGr.
Old 01-28-2011, 10:21 AM
mrcoolpop
She looks great, can't wait to build mines.
Old 01-28-2011, 11:14 PM
ho2zoo
Mrcoolpop,
Thank you very much! Actually though I can't take much credit- I bought it at a swap meet about 90% done. I just had to patch a few holes, mount the engine and electronics, and paint the cowel. That stupid Lustrecoat paint was supposed to match the Monokote, but it's turned almost black now! Oh well, maybe it was a bad batch.
The most important thing about this plane (and most warbirds) is to have a RELIABLE engine! You do NOT want to do a dead stick with it! Make sure the engine will stay running at all throttle levels before you take off! Like I said above, I mounted the engine on it's side because they are easier to tune and run reliably. (I can hear all the inverted engine proponents saying, 'Oh you just don't know how to tune it properly! Mine run fine inverted!' Blah, Blah, Blah!) I have been flying for 20 years, and I know what works for me. I built the engine baffle as directed in the instructions to direct cooling air over the engine head.
So, keep the engine running, and keep the speed up on the landing approach. Good Luck!
Old 01-29-2011, 05:20 AM
mrcoolpop
That is a excellent tip about the dead stick. I didn't know that and will make sure the engine is running correctly before taking off.
Old 01-29-2011, 06:58 AM
malthepal
And never extend your flight time to the point of drying up the tank. You can always top it off and go up again.
Old 01-29-2011, 07:47 AM
Gray Beard
My Feedback: (-1)
ORIGINAL: cfircav8r
I built an F6F for a customer and talked him into this engine for his plane, it was a very scale little Sky Shark kit. The plane got finished, that was 5 or 6 years ago. It seems the fellow is so taken with how nice it is the plane has never been flown!! The RCV was a perfect choice/fit and the muffler was almost completely cowled and couldn't be noticed. To this day I still have never seen this engine fly any plane. I have seen the 1.20 running but the plane never left the ground. These engines are a perfect fit for warbirds and with the gear drive toss huge props. I would like to see at least one plane fly with one though. A very cool engine and cool/strange design.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
