How many channels do I need? >
Old 06-21-2024, 05:51 AM
rgburrill's Avatar
I've never understood why there are so many 7 channel receivers. Why not just add one more so you have as many channels as the transmitter?
Old 06-21-2024, 06:31 AM
"Cubs aren't trainers they are a handful on the ground"
Interesting. The 65hp J3 Cub is by design possibly the best full scale trainer ever built. They are intentionally easy to spin. I learned to fly in one in 1965 and they are still my favorite plane - though I eventually bumped the power up to 110 hp. One of the things I like about them is their versatility on the ground - they remind me of a jeep. They do require respect. At the time I learned to fly they had the third highest fatality rate per hour flown of any general aviation aircraft.
Old 06-21-2024, 06:42 AM
BarracudaHockey's Avatar
Think about hot dogs and buns.....
J330 (06-22-2024)
Old 06-21-2024, 10:17 AM
Outrider6's Avatar
Yep. But if you buy Pepperidge Farm buns and Oscar Myer dogs, you can stay "in synch", as I call it.
Some things make you wonder, "Was that utter stupidity, or was it planned that way for a particular reason"?
Old 06-22-2024, 05:38 AM
rgburrill's Avatar
Yep, that question has been around for many years.
Old 06-22-2024, 05:44 AM
  #31
rgburrill's Avatar
Back to OP's question, I think 6 channels is a minimum for a beginner. I like some sort of stability control system for beginners, and they usually need 2 channels. Yes, I learned with 4 but that was when gyros were expensive. SAS is cheap now with even some receivers having it built in.
Old 06-22-2024, 12:34 PM
  #32
Way back in the olden days, we had a club member who, as a side line, charged $25 to "upgrade" 4ch receivers. He found that most already had the PCB lands, and he just had to solder pigtales onto them, to bring out 2 or 4 more channels....he had more requests than he could handle. We speculate the mfg's were just shaving pennies off of the costs, with smaller cases, cheaper pin blocks, etc.
Can't say that is the case with modern receivers...but...
Old 06-28-2024, 08:40 AM
  #33
jaka54's Avatar
Why have more than 4 channels if you are a newbie?!
I started flying R/C 49 years ago on just 3 channels.
Old 06-28-2024, 02:23 PM
  #34
I learned to fly on one channel... a Testor's Skyhawk on rudder-only. Yes it flew, but I was always in search of more channels... Galloping Ghost to get 3 controls... Digital proportional with 4 channels for many years using non-digital mechanical trims to get extra functions, then an eight channel Heath Kit and I thought I was in heaven. The cost of 6 channels instead of 4 channels is very small, you're going to need the extra channels eventually, 6 channel radios are much easier to sell than 4 channel radios in case you want to quit the hobby, and even the $200 ready to fly Hobby Zone Aeroscout includes an entry level 7 channel Spektrum DXs transmitter. So I think it is false economy to buy a four channel radio. I now have the Spektrum NX10 radio. I bought the 10 channel instead of the 8 channel in order to get the larger capacity battery pack, plus I already had two 10 channel receivers.
JimCunn (06-28-2024)
Old 06-28-2024, 02:36 PM
  #35
I'm a newbie, and though I'm going to learn to fly rc, I don't plan to be the pilot on the quetz model I'm designing.
I've decided on the nx10.
Old 07-01-2024, 11:28 AM
  #36
jaka54's Avatar
And what is that???
Old 07-01-2024, 02:42 PM
  #37
Well, Google says it is a Spektrum nx10 10 channel transmitter, compatible with their 10 channel receivers.
Old 07-03-2024, 05:55 PM
  #38
We all know what a NX10 is. So Jim, I think he meant to ask what is the quetz model you are designing. I never heard of a quetz. Can't even pronounce it.
Old 07-03-2024, 06:22 PM
  #39
Quetz is short for Quetzalcoatlus lawsoni, the 4.8 meter span small morph of Quetzalcoatlus northropi (11 meter span). Until recently, the small morph was called Quetzalcoatlus species.
These were late-Cretaceous pterodactyls, warm blooded flying reptiles.
northropi and lawsoni were found about 18 miles apart in the Big Bend National Park in Texas.
Sketch is by John Conway.
Headcrest is too large, as is back foot. Flight membranes are omitted from sketch.
Old 07-04-2024, 06:13 AM
  #40
Thanks Jim. That's a very interesting project. You should post photos of the build.
Old 07-04-2024, 07:29 AM
  #41
OK, I'm still in the design stage. I initially looked at a 4 foot span, but the torso volume was too small to hold the servos, batteries, and electronics. I'm still shuffling parts around trying to fit in the torso for a 5 Foot span. These animals had tiny torsos, and a 5 foot span juvenile would only measure 4 inches between shoulder and hip. Weight for this size would be about 1.81 pounds with aspect ratio about 16.5, and flapping frequency when flapping would have been about 3.5 Hz. I may have to grind the outboard corners on 65Kg servos to get them to fit the shoulders. Batteries will probably go in the thighs. I'm still struggling with placement of the two servos that will operate the hind limbs. First flying models will be gliders.
Once I'm sure I can l get the innards in a 5 foot span, my next step will be to sculpt a muscular model of head, torso, inboard arms out to wrists, and hindlimbs in two flight configurations that I can then use to vacuum form thin plastic exterior shells. I plan to recycle old plastic milk jugs for some of that.
I've attached a photo of Wann Langston's last reconstruction of the skull of the small morph before his death. I'm going with that as a basis for the life sculpture in a personal tribute to him.
Note how low the eyes are
Qsp torso for 4.8 meter span measures 12.25 inches from hip to notarium socket
Old 07-12-2024, 10:57 AM
  #42
Jesse Open's Avatar
Where you started has no bearing on the OP'd needs.
I started 64 years ago with 1 channel!
Doesn't mean this fellow should. That single channel radio used tubes and 67.5 volt batteries.
Doubt he would want that either.
Get a better radio that can advance as you learn. Get as good as you can afford.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
