engines- -ultra stick--
ya i am loking to get an us 40 and was wondering what engine i should get
wich would be the best 2 stroke that will fit?
which would be the best 4 stroke
to fit?
all under $250
when i say best i really just want power and quality not neasarily speed...
thanx
to fit?
all under $250
thanx
MI
RE: engines- -ultra stick--
I have an OS 46FX with an 11x5 prop and a MACS muffler and it will go vertical almost limitless. It's not real fast with this prop but is very aerobatic. It may be worth looking into. What ever engine you choose, you can change the prop to get more torque and less speed if that's what you're looking for.
Denny
Denny
thunder tiger .46 hmmm sounds like it is small only a .46 do u think it is a reliable engine , right now i have a mds on my superstar and it rarely starts, runs , or stops. the thing i like about the fx is the remote needle adjustment. ok so i narowed it down a four stroke too pricey and not what i need. now lets see either the fx or thunder tigre .46...??
wich one .46 fx or tigre??
one more question so booth of these engines will provide more than enopugh power i do not want to be underpowered???
My Feedback: (19)
The Thunder 46 PRO i think is the best option. I had this engine until I crashed it due to wing failure. It has enough power to take vertical into infiniteness with an APC 11x5 prop. The Thunder Tiger 46 pro costs a lot less than the OS 46FX which costs about $115. Definately go with the TT. My .02
well thanx alot for all the replies i like the tunder tigre but it does not have a remote needle adjustment and hte o.s . has more horespower so i am gonna go with an o.s. and an apc 11x5 prop
i am relatively new to the hobbydo u think a 2 stroke will be simplier to use and maintence wise than a 4 stroke
has anybody here used an mds engine .40??
if u have do u think any of the the engienes mentioned o.s. , tt, or saito wil be better??
thanx
thanx
2 strokes will have less maintainance. No valves to adjust. Less moving parts. So for a beginner a 2 stroke is always preferred. I would say the TT 46 pro would be a great choice. I am currently buying Irvines. Because I like the engines. I also own a bunch of Saito's. Like both. Decide which you want. In your case I would suggest the TT. After gaining some experience. Why not get a 4 stroker then. Good luck.
Mark Shuman
Mark Shuman
