rubber insert for tower starter - again
lxbc75 must fit tower starter cone (1-13/32), but why on tower site is link from tower starter to sullivan rubber insert with dimension of 1-7/16 (lxbc72 and lxbc73) ???
In my case, and for my work around my hobby and if hobbico and tower (mine) starter is same cone dimension (inside) cheap rubber insert is work fine for me. but direct replacement rubber insert for hobbico starter is 1-3/16 outside dimension (lxl401). something here in tower web is wrong, what ?
tganks again
realdo
tganks again
realdo
Why worry about a typo on the Tower web site?
If it bothers you this much, have you addressed your question to Tower?
As replied to your previous post, I have the Tower starter with the expensive pink Miller insert (for 'Hobbico'), so I know first-hand that it fits.
ORIGINAL: carrellh
ORIGINAL: carrellh
i have the same pink insert in my tower starter...it fits pretty tight i must say...
john
ORIGINAL: carrellh
Thank you for writing Tower Hobbies.
If you check our website under TOWP0500, it will tell your which
starter cones to use with this item.
We appreciate your time and your business with us.
-Tower Hobbies
Realdo
