Reload this Page >
Do you all change fuel tubing?
Old 12-07-2004, 07:35 PM
Spaceclam
Spaceclam's Avatar
Default RE: Do you all change fuel tubing?
you should replace it just as preventive measure. it is okay if you dont, my pt-40 is 4 years old and has never had the plumbing changed, but i like to change it before each season just to be sure. especially if you are running high nitro contents.
Old 12-08-2004, 02:07 AM
CafeenMan
ORIGINAL: MinnFlyer
I've never changed tubing as "preventive maintenance". If it ain't broke, I don't fix it.
Ditto. If the engine starts acting up for no reason after it's been running reliably for a while, then I might change all the plumbing. Until then I just leave it alone. Fuel tubing lasts a very long time.
Old 12-08-2004, 09:53 AM
MinnFlyer
MinnFlyer's Avatar
ORIGINAL: Gringo Volador
MinnFlyer, is there any question that you cant answer with clipart or a picture?[:-]
No
When I first started on RCU I answered a few questions with graphics (You know, the "One pic = 1000 words" thing)
After a while I realized that different people would ask the same questions, so I started saving them to a special file.
That file now contains over 500 images! LOL
My personal favorites are the animated gifs:
Old 12-08-2004, 10:01 AM
Gringo Flyer
My Feedback: (18)
Gringo Flyer's Avatar
I was going to ask if you had some sort of clipart library. You should make it available as a dowload somewhere.
Old 12-08-2004, 04:22 PM
MinnFlyer
MinnFlyer's Avatar
I thought about doing that once, but I get a little worried as to where the pictures would show up! [X(]
Old 12-08-2004, 09:37 PM
  #31
cruzomatic
My Feedback: (17)
Thanks for all the pic/drawings Minn. I remember one that you personally drew up for me when I accidently epoxied the elevator halfs on my H9 AT-6 incorrectly and not perfectly level to one another. You suggested something, drew it up, I saw it, fixed it and whao-la,,, perfect. Thanks again and keep them coming please.
Old 12-08-2004, 09:57 PM
  #32
hankpajari
hankpajari's Avatar
Up until last year I would have said no but I had a piece of fuel tubing that connected the tank to the brass tube that goes thru the firewall and then connects to the carb split. Managed to have a couple of deadsticks on an otherwise never-dies engine. We figured out what happened when we filled the fuse with fuel!
Tubing is cheap, change it!
Old 01-29-2005, 08:34 PM
  #33
ELTIGRE
certainly good practice to inspect fuel lines prior to the flying season esp if they are more than a year or two old.had my share of "in the field" tank rebuilds. full scale practice is of course to visually inspect preflt/post flt & replace hoses after 10 years regardless of condition.
