 Please Explain The Different Types Of Flying >
Old 01-18-2005 | 10:08 PM
Fastsky's Avatar
Default RE: Please Explain The Different Types Of Flying
I have seen videos of slope soaring and it looks like it would be a blast to do. Unfortunatly it requires a good size cliff hopefully on the coast of a warm island which is no where near where I live. [>:]
Old 01-18-2005 | 10:16 PM
The way things are going with the Earth's climate you may not have a cliff today, but you might wake up to have one outside your window tomorrow. If you live in Nevada, just wait a couple years and you'll be on the coast.
Old 01-18-2005 | 10:22 PM
RichD's Avatar
simply put, 3D flying is CONTROLLING your aircraft below stall speed.
biggest thing with pattern and IMAC is putting the plane exactly where you want it. Flying a straight, level, and paralelle to the flightline is not as easy as you think.
BTW, we added to our club that all 3D flying will be done over the field, not the flight line, and everyone will fly the pattern.
Old 01-18-2005 | 10:46 PM
There is also control line and free flight in various forms.
Jim
Old 01-19-2005 | 07:37 AM
ORIGINAL: a65l
ORIGINAL: raideron
Try is the key word.. With all that power and control surface no one can get
the 3D plane, because it just zips and zags around all the planes trying to
get it :-) Then as the planes miss and smash in to the ground, It resumes
hovering over the mess to help clean it up:-) Of course this is to help the
other fliers to land, since the 3D plane will just Harrier to a spot landing
Just use a tennis racket and swat it out of the sky. OR better yet use the tennis racket to swat the pilot...
Andy
That's an interesting bit of advise. I guess it could work, but you would have to know the pilot and how he could react. If he was submissive and small, you just may pull it off. Of course if he isn't so small and doesn't appreciate it, it could mean that you would swiftly have a mud hole stomped in your ass. Just a theory. [&:]
Old 01-19-2005 | 09:02 AM
  #31
Fastsky's Avatar
Re: "BTW, we added to our club that all 3D flying will be done over the field, not the flight line, and everyone will fly the pattern." < Thats a great idea! I'll bring that up at our next club meeting. We made a rule at our club that heli pilots are to use the inactive runway if they are not going to fly the pattern.
Old 01-19-2005 | 09:38 AM
  #32
We show each other respect at our club. Hovering over the runway is permitted just as touch an go's are. As long as people announce their intentions, everything is fine. If someone is doing touch and go landings, I don't hover over the runway. There were a few people in the beginning who wanted to do away with hovering over the runway but that didn't get very far. I'm thrilled to see that 3D is growing faster than any other type of flying.
Old 01-19-2005 | 10:29 AM
  #33
Can someone explain what control line flying refers to? I have heard of it but don't really know what it is.[sm=confused.gif]
Old 01-19-2005 | 11:55 AM
  #34
Fastsky's Avatar
Thats an easy one. Thats where the plane is connected to wires which go out to a control handle. The control handle controls the elevator to make the plane climb, or loop as it flys in a big circle around the pilot. The wires also keep the plane from flying off into the wild blue yonder. The planes engine is adjusted for high rpm and has no throttle. The pilot simply takes off and then flys the plane until the engine runs out of fuel. [8D]
Old 01-19-2005 | 12:10 PM
  #35
ORIGINAL: Fastsky
This is not true in all cases. For instance, in C/L stunt, the engine is set for low RPM, 4 cycle. When the pilot pulls the model into a maneuver, it puts the engine under a load and causes it to revert to 2 cycle and increases RPM. In some forms of racing, the pilot has a control to shut off the fuel line and kill the engine.
