 ball links >
ball links
ball links
Old 01-10-2006 | 07:25 PM
JollyPopper's Avatar
Default ball links
You folks have convinced me to try ball link connectors in place of or in conjunction with screw lock connectors. I see Tower lists both 1/16" threaded studs and 2-56 threaded studs. Which fit the holes in servo arms and throttle arms? Which is larger, 2-56 threads or 1/16 threads, and/or what is the decimal value of 2-56 threads? I believe 1/16 would be .062. Thanks, guys.
Max
Old 01-10-2006 | 10:42 PM
carrellh's Avatar
Default RE: ball links
2-56 is slightly bigger than 1/16. I think it's about 5/64, but it might be closer to 3/32.
1/16 = .0625
5/64 = .078125
3/32 = .09375
The factory holes in servo arms are usually 1/16.
Old 01-11-2006 | 07:43 AM
My Feedback: (13)
The 1/16th will fit nicely in Futaba servo horn holes.
IIRC, JR horns have slightly larger holes. For sure, if you use the 2-56, you will have to enlarge the holes in either. That's not necessarily a bad thing, but be aware of it.
Old 01-11-2006 | 09:57 AM
You definitely wont regret using the ball links, it makes for a much nicer installation, and less chance of binding on your control surfaces.
Old 01-11-2006 | 10:46 AM
Get the threaded ones and get yourself a 2/32 tap to tap the holes in the servo arms. Much better fit that way with absolutely no slop.
Old 01-11-2006 | 08:38 PM
ORIGINAL: Lowlevlflyer
[size=2]Can a ball-link be used for a nosegear control linkage?
size]
Old 01-12-2006 | 11:47 AM
I dont have anything that has nosegear, but I would assume a ball link could be used on nose gear linkage just the same as on the other linkages.
Old 01-12-2006 | 12:59 PM
ORIGINAL: Rodney
Thinking you may have meant 2x56 tap?
Old 01-12-2006 | 04:11 PM
You are correct Bruce, sorry for the gross error.
