G.P. PT 40 MK 2 TRAINER BUILD
NJ
RE: G.P. PT 40 MK 2 TRAINER BUILD
I just glued the two sides of the fuse together and was wondering if any of you do this differently. i don't like how the instructions tell you to get the f2 and f3 formers perpendicular to the one side of the fuse, i feel this is going on the assumption everthing is cut perfect. i did this exactly as the directions said then mounted the firewall and had fuel tank floor in place, then glued the firewall w/epoxy. After it cured i was checking out my work and noticed there is a slight twist to the fuse.[:@][:@][:@] now maybe i'm just being a perfectionist but this can't be good.
I went on to test fit the front fuse bottom f4 and f5, as well as rear fuse bottomto see if would help correct this prob. Held tightly with rubber bands. and NOPE[:@]
So now here i am, pretty discouraged and wondering if it is worth going on.
Any help would be appreciated
theo nice that its finally starting to look like a plane, what motor you putting in yours?
My Feedback: (16)
Normally F1, F2, & F3 a perpendicular to the sides, so 90 degrees would be correct.
If you have a twist, one of your formers was not square.
Try to align and compromise it the best you can. Divide up the differences.
Sand relatively true. It will be OK.
enjoy,
Jim
enjoy,
Jim
NJ
so your saying try and square it up without breaking anything and at the end i'll have to sand where the stab goes to make it parallel with the wing.
thanks rcken for those photos on covering helped me out,what area is your lt 40 in so i can read it?? sorry couldnt get the pictures to load yesterday ill try it again with this thread. agvwhtboy soerry u have a twist mine didnt do that,i was wondering how you was coming along. im putting in a os40 la in mine,ill try to get the pictures in as it was my most frustrating day of building,one of those days i guess you just have to walk away from it,my big fingers got in the way so much putting the engine it ,not much room to work in there
#31
hey it worked today so what about the first picture you can see the glue,does that show up when covering,i did sand the other side it looks better biut i didnt want to take off to much wood thanks steve
#32
okay i couple of new beginners like myselve has sent me a pm having problems with the doublers on the inside of the fuselage,i think that avgwhtboys problems with the twist started here as well. how does one tell great planes co. about changing the directions on glueing these on with 30 minute epoxy instead of ca medium in which you dont have enough time to alingn them properly?i think i got lucky when i did mine but others are not
#33
NJ
i don't think you will see though the skin unless you use clear.
well i glued the bottom and other two forms in. I guess it was because i was wearing my glasses last night. as thick as they are, it must have changed the perspective i am used to looking at.
I'm using a os.46 FX in this bird.
i'm gonna try to post some pics here in a min.
#34
NJ
i finished a few more things since i took these but here is my pt40 in progress. and a picture of the snow sled that the engine is coming off of.
#35
here is where im at so far with the engine mounted,landing gear all installed,just to take it off again. hey avgwhtboy,it looks good so far keep it up and the pics too thanks steve
#36
the fuselage is just about done except all the sanding is yat to be done. after cleaning up the work area ill start on the wings tonight
#37
NJ
question: how far back in the FUSE does that wedge have to go? should it be flush with the sides? in order to get it flush i would have to sand it down.
help is appreciated
AWB
help is appreciated
AWB
#39
okay guys i need some help please,these are the pictures of my first wing build and the trailing edge is warped big time as you can see in the pictures,i tried getting this to go and pin it down but its hard so i thought id stop to see what you guys think should i proceed or any fixes,and is this normal for this piece to be so bad,up untill this point the kit has been great im sure there is a fix thanks steve
#41
RCU Forum Manager/Admin
My Feedback: (9)
I took a look at the pictures in your post and you are correct, that trailing edge is pretty well warped. My first advice would be to call GP and discuss with them how badly the trailing edge is warped. I'd direct them to the pictures in your thread to they can see for themselves. It's been my experience that GP will more than likely take care of you and send you a new trailing edge. If for some reason they don't send you a new part you can still fix this one. The best way to take care of it would be to wet the trailing edge and then pin/weight it down on your building board and let it dry. It should be straight after it dries out. Double check to see if it's straight and then you can use it on your wing. But the first thing I would do would be to call GP and see if they will replace it.
Hope this helps
Ken
Hope this helps
Ken
#42
jim,ken,thanks guys i didnt think i should be using it so im gonna get a hold of GP I just emailed them the pictures and ill try them tomm on the phone,my other trailing edge is nice and straight i can see if it was a slight warped but i think this one was way out,ill let you know what happens,i think i can use my straight one and continue untill i hear something thanks again steve
#43
I'd have to say, quality of some of the long pieces of wood was probably my one real complaint on this kit. (I built this kit myself and learned to fly with it). For me, the problem was the aileron strips, so you might want to take a look at those too to see if they're going to be suitable. I ended up replacing them because they were warped so badly.
#44
Hey avgwhtboy,
I thought I'd comment on this comment you made earlier in this thread (didn't start reading the thread till this evening):
Personally, I cannot strongly enough recommend against doing this. Even with the lesser dihedral this plane has plenty, and quite frankly may have too much. It's absolutely steady with the "sport" wing, and recovers very well. (If anything, I'd almost say too well, I've sometimes wondered if the plane actually flies too well.) However, one thing I've noticed is that this plane can definitely catch a crosswind with the wing, especially when doing things like taxiing. Add another, what, 3 inches of dihedral, and you're going to have problems flying with any crosswind at all.
Oh, for the record, I used the rubber band wing. I'd say it's personal preference. Most accidents I've seen made while I was attending student nights either a) left little to no damage at all (ditched in the corn or soy from low altitude), or b) left plane in pretty bad shape, and whether the wing was bolted or rubber banded wasn't going to make a difference).
Now the dihedral is a personal pref. I had this discussion last night also. I'm going with the full amount. Yes it wont do rolls as easy but I want this to be the easiest flying plane as it can be.
#45
NJ
roger that piper,
i think i'll take your advice and that of others and go with less dehidral. i understand what you are saying about a cross wind.
What do you think is the max wind speed that this plane can be flown in? I've flown it on the G2 with the wind all the way up and it still flew.
looks like i might be able to catch up with you now theo/steve.
#46
My Feedback: (16)
As for the greater dihedral,
I didn't have a PT 40 but another plane with no ailerons and lots of dihedral. It looked like a pigeon flying.
Anyway, you absolutely could not trust flying that plane in a cross wind because the wind would get under the wing and cause it to flip or cartwheel on the ground.
All the PT 40's I've seen had ailerons and very little dihedral. Nice looking and great flying.
Enjoy,
Jim
Enjoy,
Jim
#47
well i called GP today and they are sending me out new ones but i wont get them probably for 4 days,bumming,i tried to get it faster but they said that was the best they can do,OH well they didn't have a problem sending me new ones they didn't even want to see the pictures i took,yes avgwhtboy you should get caught up with me now,guess all i can do is sand away on the fuselage and wait very impatiently. i will be putting ailerons on mine and I'm going with the B wing as well,,,think ill glue some toothpicks together tonight!!!!!!
#49
NJ
ORIGINAL: avgwhtboy
for the best finish all that has to be sanded off.
and i to am going with the B wing i didn't realize the A had 8". they should make the kit so you can choose between, 5" and 0" dihedral.
Also i was wondering about the elevator stab and rudder; Would it be better to wait on mounting these until the wing is finished and mounted on? because isn't it more important to have the wing square with the FUSE and then adjust the stab to be parallel to the wing. it seems it would be easier to make adjustments to the stab instead of doing it the way the book tells ya.
thanks
and theo i probably have more sanding to do than you[sm=spinnyeyes.gif]
#50
