 undoing glue! >
undoing glue!
undoing glue!
Old 06-13-2006 | 05:21 PM
Default undoing glue!
I glued something on my rc plane a while ago and now im having trouble taking it out, any tips on loosening the glue (30 min. epoxy).
Thanks, Dave Trimmer
Old 06-13-2006 | 05:26 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: undoing glue!
Dave,
I hate to be the bearer of bad news, but if you glued it with 30 minute epoxy then it's pretty much going to stay where you put it. About the only way you're going to be able to get it off is take a razor saw and cut it off. Sorry for the bad news.
Ken
Old 06-13-2006 | 05:31 PM
thats fine its only the dowel for the elastics on my trainer it will just be a little harder to put on th elastics.
Old 06-13-2006 | 05:38 PM
Missileman's Avatar
It may be better to leave it alone but I did here something about this very thing.
I was listening to a home improvement show last weekend and someone called in with epoxy on their porcelin shower and the answer given to remove that epoxy was oven cleaner. Don't know if it will work and should be tried on a couple of scrap pieces first.
Old 06-13-2006 | 06:35 PM
If the piece is accessable, try heating the glue joint with a heat gun ( normally used to shrink covering). Heat and work the piece loose with pliars or similar. It may come loose quite easily. I have used technique several times with success.
Good Luck.
DaveB
Old 06-13-2006 | 06:49 PM
My Feedback: (13)
I would second Dave,s recomendation if you can lightly spray not soak the area with water so you don't burn your wood 30 min. epoxy requires a bit of heat.
Old 06-14-2006 | 08:30 AM
B.L.E.'s Avatar
I recently unglued a plywood firewall glued in with 30 min epoxy. I used a heat gun and a lot of patience. Once you get the epoxy up to about 400 degrees F, it softens and you can pull the joint apart.
