 Lead Weight on Solid Wing - Pics >
Old 01-06-2007 | 09:37 PM
garywi's Avatar
Default Lead Weight on Solid Wing - Pics
HI,
My plane needs two pieces of lead to balance. The wing tip is fiberglass and then balsa sheeting. I usually peel back the monokote and place inside the wing, but that will not work here.
Do I just epoxy the lead to the outside? That would look aweful, plus disrupt the airflow a bit.
Old 01-06-2007 | 10:32 PM
horace315's Avatar
My Feedback: (15)
Default RE: Lead Weight on Solid Wing - Pics
i have drilled solid wing tips and epoxied weights in and just covered them.i dont think the weight would be that much of a drag on the airflow but would look tacky on the outside
Old 01-06-2007 | 11:06 PM
I don't know how much weight there is in "2 pieces of lead" so I'm not sure if this will work.
Get some lead shot from fishing tackle or shotgun shell reloading supplier. Figure out how much shot it takes to match "2 pieces of lead". Take a little away from that pile and put back in bag. Drill/cut small (1/2 inch) hole in bottom side of wing tip near tip rib. Mix 15 minute (or longer) epoxy sufficient to mix with the lead shot you have out. Stir well, better to have a little extra epoxy than not enough here. Carefully trowel this mixture into the wingtip and stand the wing on it's end to get it all to the very tip.
Let dry and cover hole.
This can also be done in the first bay inboard of the tip and may be easier to patch since you have glass tips.
Is that an ARF or a kit?
Old 01-06-2007 | 11:37 PM
garywi's Avatar
Thanks. This is an ARF. I am thinking of cutting a hole in the wing, and then recovering with Ultrakote.
