Plastic + Foam what glue? CA+or Epoxy?
My Feedback: (12)
NY
Hey,
Just got my sky scooter!:
I got a question what glue should i use to glue foam and plastic together?
CA+
30 min epoxy?
CU!
CA+
30 min epoxy?
CU!
Nik,
My sky scooter was all put together when I bought it. What particular pieces are you wanting to glue together? If it is the gear box to the fuse then you can use a hot melt blue gun, that is how mine is secured. You can only use Oderless CA as regular CA will eat the foam away. If you don't want to use hot glue then I would use epoxy. you can also use good old Elmers glue.
