Reload this Page >
Evolution .46 NT question-dropping the flywheel
Old 03-02-2008, 04:31 PM
zig123
Default Evolution .46 NT question-dropping the flywheel
Hi,
I have advanced to my fouth plane a Cessna Cmpro 182 50. I want to reuse my original Evolution trainer .46 that I have on the Alpha I learned to fly with.
Can you just take the flywheel off or do you need to get some replacement spacer/washer thingy?
Of couse I'll be using a 12/6 two blade Western Air Screw prop.
John
Old 03-02-2008, 05:03 PM
bruce88123
Default RE: Evolution .46 NT question-dropping the flywheel
ORIGINAL: zig123
Hi,
John
The flywheel can simply be pressed off of the hub.
Perhaps you mean a Master Air Screw MAS prop? 12/6 is a lot of prop for that engine. 11/6 would be better suited to the engine or maybe a 12/4.
Old 03-02-2008, 05:43 PM
zig123
You're right it's a Master Airscrew GF 3 series 12/6 same size as my Beaver with a Magnum .46 engine. Flies fine.
Zig
Old 03-05-2008, 11:43 AM
srk866
JUST SUPPORT THE FLYWHEEL IN A VICE AND KNOCK THE CENTER OUT
Old 03-05-2008, 12:15 PM
opjose
opjose's Avatar
An alternative to knocking out the flywheel, is to merely purchase another prop hub from Horizon.
This permits you to put the flywheel back on if you ever need to.
Old 03-05-2008, 01:43 PM
SKYHI1
SKYHI1's Avatar
I have an Evolution Trainer Power System. It is a nice .46 engine. I talked with customer service at Horizon, he recommended I use the prop driver for the Evolution 46NT. My problem was when mounting a 2 blade prop the plastic spinner backing buckled. I solved this by adding a small washer between the current prop driver and the plastic spinner back. I did not see any difference in rpm's after this fix. I like the engine, I put it on a new Sig 4*40 I will maiden this spring if it ever gets to the Chicago western suburbs.
Here is the part number to help you find it on Horizon's website.
Email a Friend $1.99
EVO100219 by Evolution Engines
Frank
