 My Glow Starter won't fit on the glow plug!!!!!!! >
Old 06-02-2008, 03:22 PM
Fly or Die's Avatar
Default My Glow Starter won't fit on the glow plug!!!!!!!
ok, so I'm building my first glow plane
I just got a used Saito 82 GK for it, I was just looking at it and found out that my glow starter won't fit on the glow plug, What's the problem here!!!!?
Here's the glow starter, [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRXK8&P=7[/link]
Somebody please help me!!!!!!!!!!!!!!!!!!
Old 06-02-2008, 03:28 PM
Fly or Die's Avatar
Default RE: My Glow Starter won't fit on the glow plug!!!!!!!
Update,
I just got it to fit but it kind of stretches out the part inside, is that how it's supposed to be?
Old 06-02-2008, 03:29 PM
opjose's Avatar
Link no workee....
Old 06-02-2008, 03:48 PM
Fly or Die's Avatar
sorry, I'll try to fix it
Old 06-02-2008, 03:50 PM
Fly or Die's Avatar
there ya go, all fixed
Old 06-02-2008, 05:25 PM
My O.S. 120 pumper won't accept a glow starter either. The fix is to use a remote on it. O.S. sells the hookup kit.
http://www3.towerhobbies.com/cgi-bin...?&I=LXBZ91&P=7
and then you need something like this to give you a place to hook the glow igniter to
http://www3.towerhobbies.com/cgi-bin...?&I=LXD693&P=7
Some assembly required. The O.S. glow plug connector will fit the recessed head where the Dubro clip will short out on a fin, at least on the four strokes I have There others but they use the same end as your glow stick only shorter. You would have the same problems.
Don
Old 06-02-2008, 05:37 PM
fly,
you need to pull the T handle back and then put it over the glow plug and release the T handle if its a regular glow plug it should fit it fine.
bassman
Old 06-02-2008, 08:16 PM
Fly or Die's Avatar
yeah, that's what I did and it worked, I kind of figured that the first time but was to afraid to force but now I realize you kinda' have to
thanks everybody, another successful help thread here on RCU!
Old 06-02-2008, 09:49 PM
Nathan King's Avatar
ORIGINAL: Fly or Die
Yeah, there's a spring loaded center piece in the ignitor that will be forced up a little by the pointed top of the glow plug. This ensures proper continuity through the plug.
Old 06-03-2008, 12:08 AM
opjose's Avatar
That "interlock" is quite useful...
It may prevent the ignitor from falling out and dropping into the prop, and then the prop sending it flying into the middle of your forhead, resulting in a big bump....
Oh, wait, that's what happened to me!
Old 06-03-2008, 12:16 AM
On the other hand, it make the plane nose heavy if you forget to take it off and try to fly Now how do I know that????
Don
Old 06-03-2008, 06:32 AM
Fly or Die's Avatar
he, yeah I got it, thanks guys
Old 06-04-2008, 06:38 AM
When all else fails, read the directions.
Old 06-04-2008, 10:52 AM
My Feedback: (-1)
Most of the glow igniters I have seen don't come with directions.
I have the tee handle types and the push and twist type. Both work pretty good.
Old 06-04-2008, 11:32 AM
My Feedback: (18)
brett65's Avatar
ORIGINAL: Campgems
Don
No way, Seriously?
Old 06-04-2008, 12:49 PM
ORIGINAL: brett65
ORIGINAL: Campgems
Don
No way, Seriously?
It's true, so to compensate I add lead to the tail. [X(]
Old 06-04-2008, 01:44 PM
My Feedback: (18)
brett65's Avatar
ORIGINAL: flymac
ORIGINAL: brett65
ORIGINAL: Campgems
Don
No way, Seriously?
[sm=teeth_smile.gif]
Old 06-04-2008, 03:25 PM
BuzzBomber's Avatar
ORIGINAL: Campgems
Don
Hey, I feel better now that I know I'm not the only one. I was wondering why the Tigermoth needed so much back elevator trim that flight...[:@]
Old 06-08-2008, 04:31 PM
Fly or Die's Avatar
ORIGINAL: Gray Beard
yeah, some stuff I got, didn't have directions so I figured it out on my own and everything turned out OK.
I guess I just have a natural talent for this stuff
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
