Reload this Page >
Typhoon 2 3D with Spektrum DX6i - how to setup dual rates??
Old 06-02-2008, 05:30 PM
cleansho93
cleansho93's Avatar
Default Typhoon 2 3D with Spektrum DX6i - how to setup dual rates??
Hey guys I just ordered a Typhoon 2 3D and I will be putting in a Spektrum AR6200 receiver for use with my DX6i transmitter. I have never had to setup dual rates on this transmitter before and I had a few questions for those of you who may have experience with this.
Ok so I know how to access the dual rate settings in the DX6i and I understand what they do. My question is how to properly setup the dual rates to acquire the throw that I need for this plane?
I would assume that I will adjust my high rate setting so that at 100% servo travel I will be reaching the correct throws for high rate. Now how do I know what percentage to adjust to in the dual rate mode to adjust for low rate throws? Also wil I need to adjust the exponential for the low rate setting?
If anyone is using this radio with the typhoon 2 and can let me know what settings your using for your dual rates and expo that would be great.
Any info on this will be greatly appreciated.
Old 06-02-2008, 08:21 PM
bigedmustafa
bigedmustafa's Avatar
Default RE: Typhoon 2 3D with Spektrum DX6i - how to setup dual rates??
Your settings for dual rates are kind of a matter of personal preference. You might set your low rates to 70% or so and then adjust them up or down based on your flying experience.
Old 06-02-2008, 09:35 PM
cleansho93
cleansho93's Avatar
ORIGINAL: bigedmustafa
That makes sense. I'll just back the percentage off a bit on low rate until I get good at flying it. Then I'm sure I'll be wanting to fly it in high rate all the time. I've been flying my Superstar .40 glow plane quite a bit and have gotten good at that, inverted flight, loops rolls etc... The manufacturer gives you preset high and low rate throws for the flaps and thats what I was basing this off of. Like you said though, I'm sure its all just a matter of preference. I'll give 70% a shot when I get it. Thanks!
Old 06-02-2008, 10:41 PM
ErikElvis
It really depends on your planes total throw but I was told in general use 35-40 for low and double the high. This may be different for stunt or speed planes. But to start I used 35 for low on my minnow and 75 for high. The low was to low and sluggish to respond. I upped it to 50 and left the high at 75. It flies pretty good at that rate.
Old 06-02-2008, 11:06 PM
cleansho93
cleansho93's Avatar
ORIGINAL: ErikElvis
Well, from what I understand lowering the percentage also lowers the sticks sensitivity around the neutral position (this is where the exponential adjustment comes in to play). By using + or - expo (which ranges from: -100% to +100%) you can adjust the sticks sensitivity around neutral, increasing sensitivity by adding - expo, decreasing sensitivity by adding + expo.
Again this is how I understood it reading the DX6i manual. So, I would assume by running a % of 75 at high rate you would be losing stick sensitivity around neutral position unless you also were using some - expo.
Because of this I plan on adjusting my servo travel length to get the desired high rate throws. This way I can leave the rates at 100% in high rate mode, and use something like 60 or 70 and -expo for low rate. Does this make sense? Am I correct in understanding how expo works? Its the best way I can think of to do it right now. Unless anyone has any other ideas? Thanks
Old 06-02-2008, 11:13 PM
ErikElvis
Im with ya. I dont quite get it either. Im pretty sure the D/R increases or decreases the throw of the surfaces from 0-100%. The expo increases or decreases stick sensitivity. I dont know which way that works though. I was just setting the dr and expo at same percentage for low and the same for high. ie; low dr 50% expo 50% high dr 75% expo 75%. I dont seem to get the expo.
