fuel system for cowled airplane
TN
I want to set up a fueling system for an airplane with a cowl. I've used a slimline system, however, this caused problems so I want to do it the old fashioned way. Any help from a "schematics" standpoint would be appreciated.
NE
RE: fuel system for cowled airplane
Brett, with a single fuel/supply line, maybe, but probably not. The pressure in the line may be enough to push past the needles and flood the engine. With a three line setup, the chance is lower, but still there. I've occasionally had issue with some 140-160 YS's flooding from fueling, but it is not common. I resolve it by clamping hemostats on the supply line when fueling. -cheers
My Feedback: (18)
OK
Does anyone have any good ideas on how to know when the tank is full other than when it starts running out of the muffler. I have seen a section of line running out and back into the cowl that I guess went to the muffler?
RCU Forum Manager/Admin
My Feedback: (9)
brett,
If the carb is closed there is little to no fuel that will get into the carb. If your muffler is pointed downwards the fuel will run out of the muffler when the tank is full. Yes, you will lose a little fuel like this. If you have a place where you can get to the muffler vent line when it's in the cowl then what you can do is split the muffler vent line there, and then rejoin it with a piece of brass tubing. When you are ready to fill the tank pull this line out and split it apart. Now when the tank is full the excess will come out this line and in to a catch bottle if you use one. This works well when the muffer isn't pointed down where excess fuel will drain out through it.
Hope this helps
Ken
Hope this helps
Ken
ORIGINAL: brett65
There are several ways that you can go with fueling the tanks, but just don't expect every model that you have to need to use the same kind or even the same number of lines. For instance, my OS 160 twins can't and won't run with exhaust pressure. I use a 2 line system on them, but in the same plane with a gas engine, I use a 3 line system. One to the carb, one for filling, and a dedicated vent that is attached to a scale fitting. The more you learn, the more you learn.
Bill, AMA 4720
WACO Brotherhood #1
TN
Ken,
I was thinking more along these lines. I've photoshoped a pic of the Aeroworks Edge 540T .46-.61 online manual. The white connectors are Sullivan Connectors from Tower. A few questions:
1. Will this work?
2. I had an idea to use a 3 prong for the line from tank to carb that way there would be no disconnecting any lines. Obviously plug it when ready to fly.
3. Regarding the muffler line, once the tank is full would the fuel run out the open connector therefore eliminating fuel going into the muffler or should I just stick to a two prong on the muffler?
M. Ross
1. Will this work?
M. Ross
My Feedback: (13)
here is some examples of a fueler location.
the first is the overflow set up jigeye referenced to the line sits in a aluminum bracket I made for my P-40 its connected to a "T" fitting at the pressure line from the muffler, I just pop the plug and fuel exits the line when the tank is full the muffler is fully enclosed in the cowl so there is no access to the pressure line,it prevents the muffler from filling up since it sits quite flat next to the fuse.
second is the set up on my Mustang,the EZ fueler is at the same location as the P-40 mounted to a plywood bracket in the engine area and a small hole in the cowl for the fuel probe to stick through.
the third is located in the fuse of my P-47,I glued the light ply mount to the inside of the fuse sheeting to beef up the area so when pushing or pulling on the fueler there won't be any stress on the area,the P-47 has a pumped engine but it doesn't matter where the fuel dot/fueler is locatedI chose the fuse for cosmetic reasons.
