Reload this Page >
sky raider mach II
sky raider mach II
Old 08-20-2008, 10:06 PM
joco1
Default sky raider mach II
would a os 55ax be too much in a sky raider mach II?
Old 08-20-2008, 10:16 PM
tIANci
tIANci's Avatar
Default RE: sky raider mach II
It would not be but if you want to do it to get tons of speed I think its pointless, the plane can only go so fast, but with the 55 she will have unlimited vertical.
Old 08-20-2008, 10:26 PM
ChuckW
ChuckW's Avatar
ORIGINAL: joco1
Yes. These fly plenty well with a plain bearing .46 such as an OS .46-LA. The .55 is a great engine but just not needed to have fun with this particular airplane.
Old 08-20-2008, 10:31 PM
joco1
thanks guys. thought it would be a little much so. i thought i would ask!
Old 08-20-2008, 10:42 PM
HighPlains
It would be low powered compared to the one in this thread.
http://www.rcuniverse.com/forum/m_6862165/tm.htm
Old 08-21-2008, 10:57 AM
tIANci
tIANci's Avatar
My EP conversion of the SkyRaider was pulling about 1,000W. It turned a 12x10 prop at about 9,000+ RPM ... it has UNLIMITED vertical. I did not find it over powered, there is always throttle management and its fun to be able to pull big loops. Big graceful ones.
ID:	1016076   Click image for larger version
ID:	1016077   Click image for larger version
Old 08-21-2008, 11:03 AM
cooperd
I have a Saito 56 4 stroke on mine! Been flying it for about 8 months. I rarely need full power, or even more than 2/3 rds throttle, but it flys really well and sounds awesome! Like this plane so much I bought a second one in case I dump the original!
Old 08-21-2008, 11:18 AM
tIANci
tIANci's Avatar
Its a great everyday flying plane ...
Old 08-21-2008, 11:30 AM
hogflyer
hogflyer's Avatar
There is really no reason for a .55 on it, and it’ll probably fly better on a.46 AX or .46 Pro. We race them (most guys use the .46 AX with Macs muffler – it seems to get back to speed better out of a turn than the .46 Pro), and the new ones (pinched nose) fly in the 90 – 95 mph range.
It will fly nicely on a ST GS-40 (I have one on its 3rd season with a ST GS-40 and a Macs muffler – great combination for sport flying), and an LA .46 should work well.
Hogflyer
Old 08-21-2008, 10:50 PM
chase4556
we are doing the club racing using a thunder tiger pro 40 on them...seeing awsome speeds.
