Reload this Page >
Damaged pitts muffler
Old 08-23-2008, 11:11 PM
plugin
plugin's Avatar
Default Damaged pitts muffler
If one of the exit tubes on an aluminum pitts muffler comes off, can it be welded back into place?
Old 08-23-2008, 11:23 PM
MetallicaJunkie
MetallicaJunkie's Avatar
Default RE: Damaged pitts muffler
ive used jb weld but it didnt last long
Old 08-23-2008, 11:43 PM
plugin
plugin's Avatar
I was thinking more in the sense of taking it to some place where they do professional welding. Any ideas?
Old 08-24-2008, 05:42 AM
gunfighterII
gunfighterII's Avatar
It will be cheaper to buy a new one, than take it to a welder.
Old 08-24-2008, 07:14 AM
horace315
My Feedback: (15)
horace315's Avatar
any type of jb weld because of where it is and vibration wont hold eventually it will break again,you might find a shop that would do it for cheap.if they charged much over half the cost of a new one i would just go with new.
Old 08-24-2008, 09:36 AM
delman
I had one welded by a friend. You need to see if it would cost more to repair or replace with new. Mine is still good 6 years after the repair.
Old 08-24-2008, 09:39 AM
Rufcut
I'm not a proffessional welder, but I think aluminum is pretty tough to work with. By the time you pay a standard shop rate you could probably buy a new one.
Old 08-24-2008, 10:48 AM
Mikecam
Take it to a rad shop. Hopefully someone will help you out. A couple of minutes is all it would take but the charge just to turn on the welder could make it not worth it. Good luck.
Old 08-24-2008, 04:40 PM
brewski
They are pretty easy for a weld shop to take care of and sometime those guys do you a nice favor for small hobby jobs. Another solution is to go to Home Depot and get a package of aluminum welding rods that are used with a propane torch. It looks like silver solder sticks and is ~$5. I have some and used it on a pitts stinger and it is doing great. Just get it really clean. With a little practice you can make it look nice too.
Old 08-24-2008, 04:49 PM
jetmech05
I don't know if you can braze Aluminum..or silver solder but I'd sure take it to a welder and ask
Old 08-25-2008, 12:42 PM
plugin
plugin's Avatar
I took it to a welding shop. They charged $5 and welded both tubes back on. It doesn't look pretty but it works and the muffler goes inside the cowl. I also cut half of the length of the tubes and replaced with silicone deflectors so they don't come in contact with the floor again.
Old 08-25-2008, 01:51 PM
gunfighterII
I see your in Columbia, No wonder it was only $5 Here in the good ol USA it would have been $55 Good Job!
Old 08-25-2008, 02:07 PM
plugin
plugin's Avatar
ORIGINAL: gunfighterII
Yep, here in Colombia those things tend to be cheap. Don't envy me too much, I have to pay double of what you guys pay for almost everything else!
Old 08-25-2008, 02:23 PM
plugin
plugin's Avatar
Here are some shots of the job. Please excuse the lack of focus on shots 2 and 3.
ID:	1019252   Click image for larger version
ID:	1019253   Click image for larger version
Old 08-25-2008, 03:32 PM
alfredbmor
alfredbmor's Avatar
They look like they will last longer than the original soldering job.
Old 08-25-2008, 06:02 PM
plugin
plugin's Avatar
Yep they sure do!
Old 08-25-2008, 10:00 PM
horace315
My Feedback: (15)
horace315's Avatar
if it works that is all that matters.i can weld but wouldn't want to show it to anyone they tend to get those Popeye muskles on the welds.............
Old 08-25-2008, 10:18 PM
plugin
plugin's Avatar
It does work. I don't know if the impact bended the muffler in some way that may compromise performance. I ran the engine today and it seemed to idle OK and the performance at WOT was kinda OK to. The engine has only got 3 tanks through so I can't really tell because break in hasn't finished just yet.
Old 08-25-2008, 10:40 PM
amdhotprocessor
amdhotprocessor's Avatar
as a welder myself, I have to say that actually is decent for a hend tig weld on that thin of aluminum/
A tip on cleaning aluminum for aluminum soldering and welding USE A STAINLESS STEEL BRUSH and NEVER let the bristles touch anything but aluminum of plastic that it should be kept in.
and do the work within a few minutes or re clean. oxide is faster then you think!
There are some " aluminum welding rods" that use a torch. however they are not as good as TIG welded welds. they are good though, and it helps to have a really roughed surface as they work more with mechanical/chemo bonds to the aluminum and weaving there structure with the oxide prodused, where as the tig will MELT the two together, and the rods from the LHS will melt onto them no into them.
Old 08-25-2008, 10:47 PM
plugin
plugin's Avatar
ORIGINAL: amdhotprocessor
I'm glad to hear so. The bond seems pretty solid and I checked the inside of the tubes to make sure that there hadn't been significant volume loss inside. It appears to be totally unobstructed by the welding job.
