 Prop for Alpha 40/Evolution Trainer Engine >
Old 10-07-2008 | 11:24 AM
HampdenTech's Avatar
Default Prop for Alpha 40/Evolution Trainer Engine
I need to replace the prop. on my Alpha 40 (Evolution Trainer System Engine). I want to go with a standard 2 blade prop. I'm looking for opinions on the size. I was told a 10 X 5. I currently have a 10 X 6 (wood) Top Flite Power Point. Any other opinions?
Bob
Old 10-07-2008 | 11:31 AM
MinnFlyer's Avatar
Default RE: Prop for Alpha 40/Evolution Trainer Engine
I found that engine to run great on a 10x7, 11x6 and 11x7
Old 10-07-2008 | 11:54 AM
opjose's Avatar
Yup as MinnFlyer says.
I find that the best compromise is the 11x6.
The 11x7 will bog down a bit.
The 10x7 gives good speed, but lower thrust.
The 11x6 will not permit the plane to prop hang, but it does give it plenty of power.
Old 10-07-2008 | 12:02 PM
mclina's Avatar
I use 11x6 APCs on mine and they work great.
