Help Setting up servos
My Feedback: (76)
ok i am setting up my servos tonight when i press the Alerions to the left which way should the left alerion go and the same the the Right and if i press up on the elevator which way should the elevator go can someone help me out here
OH
Push the aileron stick to the left and the left aileron should go up and the right aileron should go down.
Pull back on the elevator stick and the elevator should go up.
1 Post
ORIGINAL: bbrown2828
What bigdanusa told you is right on the money but...................if you need to ask this sort of question you really need help from a competent flyer to get your "pride and joy" up and back in one piece. Please follow the mountains of advice to join a club, hook up with an instructor etc, etc. Unless you are one of the very small minority who can learn to fly without assistance a club/instructor will make learning much quicker and cheaper
.Cheers,
Colin
OH
If you are that new to this hobby asking a question about which way the controls will go, which is fine, always remember: Don't get your fingers in the prop when the engine is running!
Also, as a beginner, whenever you move the sticks, just move them a slight bit, don't yank and bank them all the way or your plane will be in a position you won't be able to pull out of and you'll be out one airplane!
Get all the help you can on your first flight!
My Feedback: (-1)
ORIGINAL: Crash Campbell
Hi bbrown2828,
What bigdanusa told you is right on the money but...................if you need to ask this sort of question you really need help from a competent flyer to get your ''pride and joy'' up and back in one piece. Please follow the mountains of advice to join a club, hook up with an instructor etc, etc. Unless you are one of the very small minority who can learn to fly without assistance a club/instructor will make learning much quicker and cheaper
Cheers,
Colin
.Cheers,
Colin
GA
ORIGINAL: Gray Beard
Isn't that why he asked in the beginners forum?? I can still remember setting up my first plane and had to ask my instructor, I had them backwards. My instructor wasn't there with me when I set up my first plane with my nice new radio so I had to wait to find out for several days. They sure set up bass ackwards from what seems correct. Seemed like a pretty normal beginners question to me.
Hi bbrown2828,
Cheers,
Colin
.Cheers,
Colin
I don't think it's insulting at all to give him the advice that he doesn't yet know he needs. That's better than saying nothing and seeing a post a week or two later about how he broke his airplane.
bbrown2828- If you haven't already, hook up with a club and get some flight instruction. Even if it costs you some money, it's cheaper than going at the hobby alone and learning from mistakes. The other thing to set up on your airplane is the center of gravity and control throws. Your manual will have the recomendations for those. Put your CG near the front of the range and balance your airplane laterally by hanging it on the prop shaft and rudder hinge with string.
GA
ORIGINAL: jester_s1
[quote]If you are that new to this hobby asking a question about which way the controls will go, which is fine, always <u>remember: Don't get your fingers in the prop when the engine is running![/</u>quote]
For instance, I didn't find the bolded and underlined to be terribly constructive as this is fairly obvious to most, but hey!, maybe that's just me.
OH
I've seen experienced flyers get their mind so wrapped up in something else they forget about safety and end up getting their fingers in the prop.
An experienced guy in our club had a 40%er with about a 24 inch prop and a 150 DA Gas engine and when he went to start it from the front (the plane wasen't tied down to anything) he didn't realize the throttle lever was on full and he about lost his whole arm when the plane came towards him and he tried to stop it!
Safety First! Beginner or Expert!
My Feedback: (-1)
ORIGINAL: bigdanusa
OH
A little extra advice never hurt any beginner.
Didn't mean to get you bent out of shape for adding a little extra to the post.
I'll "try" not to let it happen again so others won't get bent out of shape either that don't like what I add to a post.
sorry
sorry
I have seen very experienced fliers mess this up. I just remember a lifted aileron reduces lift and a lowered aileron increases lift so moving the stick left should raise the left aileron.
CA
ORIGINAL: bigdanusa
ORIGINAL: 1320Fastback
As viewed from the rear of the plane...I mean the left is still the left but now its the right????
ORIGINAL: bigdanusa
I used to mentally battle with this for years until someone taught me the "Thumbs Up" method.
1 Stand behind the plane
2 use your thumb to push the aileron stick to either side.
3 whichever side you move the stick to, that aileron will go UP
Thumb = UP
Thumb = UP
