12v gel cell battery charge
TX
My 12v 7 amp gel cell starter battery is on the dead side. How long should I charge it back up using the 600 mah wall charger?
hulio
hulio
RE: 12v gel cell battery charge
If you have let it discharge to deeply, you may have damaged it beyond restoring. Always recharge any Pb based 12 volt (6 cell) battery as soon as it drops to 11.9 volts. Two things will kill your gel cell quickly, deep discharge or to fast a charge. Never charge at more than 0.1C (700 milliamperes in your case) unless you are monitoring the battery temperature where you can stop the charge as soon as the temperature rises appreciably. If you are using the proper charger, a limited current/maximum voltage charger, you can leave the charger connected all the time as it will automatically cut off as the voltage rises to the set limit.
TX
I charged up my 7 amp gel cell battery for 13.5 hours with the 600 mah charger and it works fine. Now it will turn over my 75ax engine with no problem! Unlike last year it wouldn't even turn over any of my engines with the starter. Last year I was only giving it about an 8 hour charge and the 12v battery is 5 years old. I guess the 13.5 hour charge did the trick rather than just an 8 hour charge.
Thanks for the help,
hulio
hulio
Moderator
Lead batteries don't like to be pulled down. Top it off every time you fly. Better yet, buy a battery tender to keep it topped off all the time.
TX
My gel cell 12v battery was so low before I charged it back up that it wouldn't even turn my starter over one time and it wasen't even up against an engine. So, the 13.5 hour 600 mah charge made it like new again after being 5 years old.
hulio
hulio
