RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Cub engine mounting (https://www.rcuniverse.com/forum/beginners-85/10072114-cub-engine-mounting.html)
billd76 10-16-2010 08:58 AM
Cub engine mounting
Hi all,
Just wondering how most of you have your engines mounted in your cub? I would like to mount mine with the cylinder head down at 45 Degree angle. To get the engine in line with the fire wall center line mark I will have to dremel out a small area of the left fire/fuse brace to get the engine mount to fit properly. Or I could just mount it 90 degree to the right and just drill holes. The marks on the firewall have the engine mount off set to the left side of the aircraft. I'm putting in a OS 60 FP
JohnBuckner 10-16-2010 05:44 PM
RE: Cub engine mounting
The majority of Cub models mount the engine ninety degrees with the engine protruding on the right side just like the full scale J-3 cub has the cylinders protruding horizontally on both sides.
John
billd76 10-16-2010 08:47 PM
Thanks John,
that will be it then, bought an exhuast extention today for a 90 degree mount! good to go!
CGRetired 10-16-2010 09:31 PM
That sounds scale and ought to look realistic. Good stuff!!
CGr.
