RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Two wings into One (https://www.rcuniverse.com/forum/beginners-85/10158712-two-wings-into-one.html)
KW_Counter 11-25-2010 09:51 AM
Two wings into One
Hi,
I have two damaged wings for a WM Mach II.
One is damaged on the left, the other the right.
I am considering cutting the wings and combining to get one good one.
Has anyone ever done this?
What suggestions do you have?
KW_Counter
da Rock 11-25-2010 10:09 AM
RE: Two wings into One
Sounds like a great idea. It's been done before for sure.
RCKen 11-25-2010 10:40 AM
I've done it before several times on several different plane. No problems at all.
Ken
noveldoc 11-25-2010 10:42 AM
Just make sure the wing balances laterally. May need to add a bit of weight to one side.
Tom
TedMo 11-25-2010 01:17 PM
Just be sure not to introduce a twist into wing when putting together, this is especialy easily done if joining elliptical wing halves.
CGRetired 11-25-2010 06:25 PM
What about the spar? If you cut the two wings into two halves and then join the two good halves together, well, again, what about the spar?
CGr.
Crash Campbell 11-25-2010 07:28 PM
ORIGINAL: CGRetired
CGr.
Hi,
Don't forget to splint the spar and a little fiberglass cloth and resin would add a "belts and braces" approach.
Cheers,
Colin
CGRetired 11-26-2010 07:28 AM
Thanks.. wphew.. i thought I missed something.
CGr.
KW_Counter 11-27-2010 09:27 AM
Any suggestions on splicing the spar would be very helpful.
I have no problem glassing, just not sure where.
How big should the splint be?
This is a 40 size sport plane.
KW_Counter
Crash Campbell 11-28-2010 12:23 AM
Hi KW Counter,
The joint should ideally be four times the diameter of the spar, obviously the length remaining on each wing that is undamaged will determin the length and may vary from the ideal but anything less compromises strength. Overlap the spars as much as possible to arrive at the same wing span of the original wing, cut at an acute angle and glue together, this is much stronger than a butt joint. Then splint either side with birch or similar extending at least 1/2" either side of each end of the joint. When you re sheet the now joined and splinted wing add 4" of fiberglass cloth for a little mental reassurance:D
Cheers,
Colin
