Engine Break-In Bench?
1 Attachment(s)
Hi y'all
What is the best, easy and cheap way to build an engine break-in bench? Any suggestions? Thanks in advance[8D] Mody |
RE: Engine Break-In Bench?
Get a board, put an engine mount on it, clamp the board to a saw horse, attach a fuel tank behind the motor, a wire to the throttle, start the engine, and break it in.
Can't get much easier and cheaper than that. I don't know about the best, but it works for me. CGr. |
ORIGINAL: CGRetired Get a board, put an engine mount on it, clamp the board to a saw horse, attach a fuel tank behind the motor, a wire to the throttle, start the engine, and break it in. Can't get much easier and cheaper than that. I don't know about the best, but it works for me. CGr. I was running some larger engines and I just had to put a weight on the end of the sawhorse so it would not pull away [X(] |
Flying saw horse... what next!!! :D
Alternatively, you can do that in your actual model as well. In our country, space being a problem, we cant do the run-in around the house lest the neighbours complain. So we put in the engine in the model and do the run-in on the field itself
Ameyam |
Armody,
How about some more info on the mount in your pictures? Thanks, KW_Counter |
ORIGINAL: KW_Counter Armody, How about some more info on the mount in your pictures? Thanks, KW_Counter That Hudy set-up is for r/c car engines...that prop / shroud is only about 4-5" dia. For airplane engines, I use an old Tatone adjustable alum. test mount (still available ) that is bolted to a piece of 3/4" ply. I then c clamp it to a work-mate type bench. (I put a cement block across the lower part of the legs to keep it from tipping over @ WOT when running larger engines ) Edit: this is similar to what I have...but I use bolts instead of screws to attach it to the ply. http://www3.towerhobbies.com/cgi-bin...&I=LXR588&P=ML If ya wanna talk "cheap" ( uh.."inexpensive" :D ) just cut an engine sized notch in a hunk of plywood...1/2" (or more ) thick or a piece of 2x6 or whathaveyou...and bolt your engine to it. Just make sure it's good and secure! Rubber band a fuel tank to it and then c clamp it or deck screw it to a bench / picnic table / etc. |
I made a mount out of a piece of old cutting board and bolted it to a 2 x 4. I drilled a hole in the other end that I can tie to a tree and I set the board with the engine end hanging off a picnic table.
1 Attachment(s)
I second what CG Retired uses.
Guys / Friends
Thank y'all very much for great input, As I did check some videos and looked around the google, I found many helpful information. There are so many simple ways I learned to make your own engine break in bench. Sawhorses is a good idea too. I don't have a setup as of yet, but I'm certainly gonna set it up soon. I'd make sure to update this post with pix. Mody |
ORIGINAL: armody What is the best, easy and cheap way to build an engine break-in bench? Tie the other end around the tail of your plane. Start engine. |
ORIGINAL: MinnFlyer ORIGINAL: armody What is the best, easy and cheap way to build an engine break-in bench? Tie the other end around the tail of your plane. Start engine. |
Tying a rope would only work when you have the other plane, I have my old Evolution engine, I wanted to run it. Now I have seen a lot of easy ways so, I guess I'd make it work somehow [8D]
Thanks for great suggestions y'all.. Mody |
I break in airplane engines on airplanes.
here is the one I use. very versatile for different engines/sizes
http://www.pspmfg.com/RCEngineTestStand.html |
ORIGINAL: Ghia here is the one I use. very versatile for different engines/sizes http://www.pspmfg.com/RCEngineTestStand.html http://www3.towerhobbies.com/cgi-bin...&I=LXWVU4&P=ML It will break in any .40-60 size engine. Most ABC engines I break in while it's in flight. |
I'm gonna make a break in bench myself, I got the idea, hopefully I'm gonna start working on it next week as I'd be done with my college.
It would be a simple one, I have seen some of the expensive stuff over here, but I'm gonna make me one, and post pix over here soon.:) Thank y'all for great inputs. Mody |
I have spent 30 minutes of my life and possibly $10 worth of stuff towards my "engine research and developement facility" and that's enough to get the job done. Outside of dialing in a tuned pipe engine, I've got little use for it.
A $3 plastic engine mount screwed to a fence post is all you need in most cases. |
ORIGINAL: CGRetired Flying saw horse... what next!!! :D http://i40.photobucket.com/albums/e2...t/standsde.jpg http://i40.photobucket.com/albums/e2...tandlftsde.jpg http://i40.photobucket.com/albums/e2...st/standbk.jpg :D Pete |
Green grass in NY in December?
ORIGINAL: rambler53 Green grass in NY in December? Mine is all white!:eek::D |
Awesome test bench Wow,
I really like those pix. Next week once I'm done with my CCNA, gonna start working on my test bench. Here in TX grass is still green. I hate winds over here especially in colder months when you don't need, in summer when you need one, it's nowhere to be found[:@] Oberst great job!!!:D Mody |
| All times are GMT -8. The time now is 04:26 AM. |
